Old 10-29-2022, 10:23 PM
turbo69bird's Avatar
Default Drive shaft safety loop bolts to trans
Anyone remember those safety loops that bolt to the trans mount?
I was trying to find one for my daughters friend but a search didn’t turn anything up. He’s just starting out racing his car and I didn’t want him
To have to hack up his floor pans the car is mint.
960 HP @ 11 psi, 9.70 at 146.
Old 10-29-2022, 10:35 PM
Scratch that I found it.
For those looking it’s ram air restoration that had them.
https://www.ramairrestoration.com/ds...owerglide.html
Old 10-30-2022, 08:44 AM
form74's Avatar
form74 form74 is offline
I have the RamAir on my Formula
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 10-30-2022, 09:55 AM
Half-Inch Stud's Avatar
Took mine off due to intense rattles at mid-track. Ovalled-it for more range, then tried rubber sandwich against floor brace.
Worked, but still removed to make the fix permanent by drilling into hoop to hold the thick rubber strips.
Old 10-30-2022, 10:09 AM
78w72 78w72 is offline
PTFB has them too. i use one on my TH400 72 firebird, had to trim it a bit to fit better, runs real close to the top of the floor.
http://pro-touringf-body.com/chassis_components.html
Old 10-30-2022, 12:05 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I bought several from Indian Adventures and I thought someone picked up their product line.
Go fast, see Elvis!
Old 10-31-2022, 08:29 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Bought one yrs ago and very tight fit in a Sec gen F body. Darn thing has some weight to it,.
Old 10-31-2022, 09:32 AM
mgarblik mgarblik is offline
Was wondering if anyone has installed one of these in a 61-64 full size car? Thinking I may need one with my 4-speed car. But very small trans tunnel and lots of stuff on the way. Exhaust runs extremely close to the driveshaft.
Old 10-31-2022, 01:10 PM
Tom Vaught's Avatar
Boost Engineer
Do not need much driveshaft clearance from side to side.
If you make the hoop from .125 thick material in the tunnel area it will still contain the driveshaft.
Make the "band" wider so that you have more strength that way vs a thicker narrow width retention band.
You want to retain the driveshaft if you have a u-joint bearing failure on either end.
If you have a proper wall thickness driveshaft made, it does not have to be the same diameter as the factory unit.
The driveshaft should not fail in the center of the tube.
Retention of the driveshaft at the 3rd member of the rear axle is a bit more complicated.
The driveshaft will have some angle change as the rear goes thru its travel. The retention material can be thicker there.
And high quality "U-Joints" installed in the new tube.
It gets real ugly on a street car if you have a failure of the driveshaft or u-joints and it beats the crap out of your factory floorboard.
Tom V.
Old 10-31-2022, 03:25 PM
misterp266's Avatar
Saw this on eBay, says F car but don’t think there’d be any difference. Seems heavier but not too crazy about how they welded it.
https://www.ebay.com/itm/27153759462...3ABFBM1O7O8YVh
" Darksiders Rule "
Old 10-31-2022, 09:09 PM
4dblnkldude's Avatar
I have one from Ames. I don't know who makes them. It actually hit the driveshaft on the top ever so slightly. I had to put in the brake to make about a 5/8" offset.
Old 11-01-2022, 08:01 AM
form74's Avatar
I had to bend at the tab a little bit
To adjust perfect we had the car on the ground on wood so we could adjust , took a few try’s.
74 Formula
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 11-01-2022, 11:27 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I bought on I think form IA years ago-it is round and with the engine trans offset in the second gens I was not sure it would work unless bent to an oval shape
Skip Fix
Old 11-01-2022, 06:15 PM
younggto younggto is offline
Has anyone had a front u-joint failure with one of these in place? I have and it didn’t work out very well.
Old 11-01-2022, 06:43 PM
AG's Avatar
AG AG is offline
What happened? Any pics?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-01-2022, 07:39 PM
I’ll provide an update this weekend, just looking for other’s experience first.
Old 11-02-2022, 01:22 PM
Tom Vaught's Avatar
Boost Engineer
I know of 3 people with the same issue and the "Hoop".
All three had to replace their floorboards.
Tom V.
Old 11-02-2022, 07:39 PM
catc's Avatar
catc catc is offline
Wouldn't these mess up your driveline angle ? has anybody checked before and after?
Old 11-02-2022, 08:41 PM
I did and it did not change. I was worried about that at first. My car is a stick, 3 degrees out and 3 degrees with the loop in.
