Old 03-05-2020, 08:33 PM
nashcar nashcar is offline
Default Firebird 400 questions
I have a friend looking at what may be a 67 400. What separates the car from a standard car?
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 03-05-2020, 10:21 PM
PontiacJim1959 PontiacJim1959 is offline
The best way to ID the car is to purchase the original build/order form for the car through PHS, then there is no doubts. http://www.phs-online.com/
Obviously the 1967 400 engine, correct engine code, "067" heads, correct number Q-jet, etc.. 1967 will not have the vehicle VIN number on the engine block as that was started in 1968. So, you will want to use casting date codes found on the heads and block and should be very close in date to the build date of the car.
The 400/326HO had 2 radius rods at the rear axle while non-400 cars only had 1. The radius rods go from the axle to the body - sorta like a traction bar. This will be in addition to the rear leaf springs. I read another article that says the automatics has 2 rods and the manual cars only 1.
Old 03-05-2020, 10:35 PM
einstein's Avatar
einstein einstein is offline
The "traction bars" of the 67s were by drivetrain - depending on performance engine, manual trans and axle ratio. I believe it's charted out in the Service Manual, which is a supplement for Firebird. Even the Sprint six and the 326 HO had 2 bars with certain trans and ratio configurations.
Old 03-05-2020, 11:05 PM
OK, good to know. I am no expert on the Firebirds, but read about the "traction bars" and thought that might be a real quick reference to ID if it was an original 400 car. So easy to "fake" a lot of these cars and overpay and then later dig in and decipher the car only to find out it was not as claimed.
Old 03-05-2020, 11:38 PM
68tpls400 68tpls400 is offline
'67's are easy to identify a 400 model. They will have 3f on the data plate. Only year they did it that way.
Old 03-06-2020, 10:49 AM
Thanks a lot for the replies guys. Though I have a one owner original 69 400 I’m not too familiar with the 67’s. The car does have the two traction bars, the 400 hood and the close out plates in front of the core support. Going by Camaro specs, the 400 hood is original also.
69 Z 302 M21 3.73
69 FB 400
Old 03-06-2020, 12:56 PM
Hikin Mike's Avatar
Unrelated, I took a look at your 69 Firebird 400 pictures on your website. Great job!
- Mike
Old 03-06-2020, 01:28 PM
Thank you Mike, that may be the most original 69 400. One thing I found was a restrictor in the return fuel line which I replaced when restoring it, puzzeling. Got a picture with the original owner with it after it was finished.
69 Z 302 M21 3.73
69 FB 400
Old 03-09-2020, 03:55 PM
Inogame Inogame is offline
67 automatics only had a single radius rod, no matter what motor.
The Following User Says Thank You to Inogame For This Useful Post:
Old 03-09-2020, 05:26 PM
This car does have two.
69 Z 302 M21 3.73
69 FB 400
Old 03-09-2020, 08:42 PM
einstein's Avatar
I found the supplement manual online and captured a screenshot of the radius rod application chart.
http://thefirstgensite.com/html/F67svcmanual.htm
Old 03-09-2020, 09:00 PM
einstein's Avatar
I forgot about the air baffles between bumper and radiator support, they also had the lower air dam. The 3 pieces were on all 400s and all A/C equipped cars. Other 400 specific items were 400 badge on trunk lid and "hockey stick" bright trim on the grille dividers, and of course the 400 scooped hood.
Of course your buddy should get off the dime for the PHS documentation.
Old 03-13-2020, 06:41 AM
frankyboy455 frankyboy455 is offline
Engine Unit Number on block should show on PHS
Old 03-13-2020, 06:43 AM
670 heads on a 1967 firebird 400, not 067
Thread Tools
Display Modes
