Old 07-07-2020, 05:04 PM
1_Wild_Cat's Avatar
1_Wild_Cat 1_Wild_Cat is online now
Hey roht -- If you go with the SPC adjustable uppers, do you have to switch to discs or could you keep your drums?
Old 07-07-2020, 05:21 PM
rohrt rohrt is offline
No need to switch to Disc with the SPC adjustable uppers.
The lowers are the only problem as the BJ area of the arm sits in a pocket of the drum backing plate. If I did have disc brakes then he would recommend the tall lower BJ either in the stock arms or an aftermarket arm, as it corrects a lot of bump steer.
Old 07-07-2020, 06:41 PM
1_Wild_Cat's Avatar
Oh...I see. I was thinking about spreading out the expense and doing the suspension separate from the brakes. Thanks for the reply.
