Old 04-30-2024, 03:57 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Originally Posted by importsmasher View Post
Maybe I'm missing something, but the first question that comes to my mind is how do you start an engine with that much timing? My cars have difficulty starting with ~15 degrees initial timing (they'll crank real slow). How does it work with 40-50 degrees?
Importsmasher
You would have to separate the ignition from the starter. Start cranking with ignition off. Then turn on ignition. Some people do this with locked distributors and/or high compression. At least they did many years ago. Now there are better starters, 16 volt systems, auto-retard, etc.
Old 04-30-2024, 06:30 PM
george kujanski's Avatar
After all the time that large automakers have spent on designing engines, this one individual has all the secrets. He also probably has the secret carburetor that enabled large V8s to get 100 MPG but it was bought from the inventor by Big Oil and secretly stashed away.
George
The Following User Says Thank You to george kujanski For This Useful Post:
Old 05-01-2024, 10:32 AM
With his particular set up he has a distributor that is locked out, (no centrifugal advance), but does have vacuum advance. So, he has 18 initial, manifold vacuum advance adds the other 25-30 degrees at idle and part throttle cruise. Full throttle timing reverts back to 18, which he claims is where his boosted 8.0 compression motor runs best. I guess that it's easy to crank @18 with the low compression.
I suppose there's nothing really wrong with this approach, on this particular engine, but the way he comes across as some self-proclaimed super tuner, savior of the world is very off putting to say the least. He even made a recent post comparing himself to Nunzi Romano and Nikola Tesla. I'll try to find it and post it here, it's hilarious
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
The Following 2 Users Say Thank You to Singleton For This Useful Post:
Old 05-01-2024, 10:54 AM
Megalomaniac
ID:	632972   Click image for larger version
The Following User Says Thank You to Singleton For This Useful Post:
Old 05-01-2024, 11:19 AM
He is THE ONE!
George
Old 05-01-2024, 11:30 AM
455dan's Avatar
455dan 455dan is offline
George
I got a kick out of this tune on a 1999 Vette. 40 MPG hiway about 4 years back
Lean burn map tune, eco Vette Wide band O2 as well low load cruise runs at 17:1
314.6 miles travelled used 7.813 gallons 40 MPG NOX level higher probably
140K miles and all emissions devices still on the car. Car makes more HP and torque when opened up than it did with stock factory tune.
https://youtu.be/vNIZ25eBMco?t=945
1984 RX7 Jim Hand style 455 /200 4R Project car
67 White/Gold GTO 4 speed sold, 1968 GTO 4 speed sold, 1969 GTO auto sold, 68 Firebird 400 4 speed (455) sold, 65 GTO Night Watch Blue 4 speed sold, 64 GTO Nocturne Blue 4 speed sold, 71 GTO Gold auto sold. 1975 Formula 400 auto sold.
Hopefully to be restored, H-"O" Racing 73 Trans Am SD 4 speed,
Sons 70 Formula 400 auto, and wife's 1974 AMX 360 auto, 1975 Jeep Honcho 4x4, 1965 Buick Special post
Old 05-01-2024, 11:58 AM
Cardo's Avatar
Cardo Cardo is offline
Isn't "12.5/1" richer?! What?!
The Following User Says Thank You to Cardo For This Useful Post:
Old 05-01-2024, 12:21 PM
78w72 78w72 is offline
This particular engine, in his "stage 3 super pace car" does have something wrong with that type of tune... it detonates at part throttle & 6psi of boost so bad that it requires 3-4 bottles of octane boost or race gas.... it wasnt built to do that, its what is needed to stop the detonation and get anywhere near the factory 9psi boost.
Bet that car doesnt run any better than a mild properly set up turbo 301 & definitely nowhere near as good as some of the higher power 301t's being done today... yet after all the bragging he wont even take it to the track or actually have the engine dyno'd! LOL!
Old 05-01-2024, 01:14 PM
65 Lamnas's Avatar
The only issue I see is unsuspecting hobbyists trying to replicate his "Max Efficiency" super tune...they then blow their head gaskets from the 58 deg of initial timing. It's actually already happened....SMFH
Old 05-01-2024, 01:26 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
"Legend in his own mind"
I got into it a while back with that guy on the bookfaces and the admins took his side. Which tells me all I need to know!
Old 05-01-2024, 01:35 PM
65 Lamnas's Avatar
The admins and moderators on the groups he's in are actually his minions....
Old 05-01-2024, 01:38 PM
Ben M.'s Avatar
That's why I stopped sharing technical information online. Getting browbeat by some flunky's toadies isn't exactly a good time. I'll let them be wrong.
Old 05-02-2024, 10:52 AM
Got this from a FB group, looks like he has a book out now about his "ooper dooper pooper scooper stage 9 TA! LOL!
