69 Firebird pitman arm
I have a 69 Firebird with manual steering, I want to convert it to power steering, the pitman arm on my manual steering is curved, is the pitman arm for power steering also curved and does it matter what ratio the gear box is or does one 69 Bird power steering pitman arm fit any ratio gear box, AND DOES ANYBODY OUT THERE HAVE A 69 FIREBIRD PITMAN ARM FOR POWER STEERING, PLEASE HELP,
For what it is worth..I had thought that the Manual pitman arms were straight and the power ones were curved...maybe that is for 67-68?
The one on my 69 400 bird is curved and its has power steering. If that helps ?
Mike B 69 RS Z28 X33 69 SS 350 clone 68 Rs/SS 396 Project 69 firebird 400 project |
at any rate , I have a pitman arm and center link from a PS '69 V-8 bird |
any V-8 has the curved arm to clear exhaust
OHC-6 and Camaros used straight arm |
Thanks, forgot about the OHC 6 and knew about the Camaros (having six of them sitting here)...so same pitman arm for Manual or power box - mental note to self.
no not the same, yes 67-69 birds w v8s used curved pitman arms, and p/s- m/s pitman arms do not interchange!
Had a manual box '67 400 car a year or two ago...someone had cut and welded the pitman arm back together |
Look at E-bay item # 300241771200
$5 plus shipping isn't to bad.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
The sector shaft is larger on a power steering gear, and the hole in the power steering pitman arm for the sector shaft is larger as well.
Manual and power steering pitman arms will NOT interchange. Both manual and power steering pitman arms are curved on V-8 67-69 Firebirds. |
