#61
I used the Lightening Dark units based on FJ’s recommendation-literally night and day difference.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
The Following User Says Thank You to grivera For This Useful Post: | ||
#62
LOL Isn't that just crazy? Imagine 4 of those at night.
The Following User Says Thank You to Formulajones For This Useful Post: | ||
#63
Insane - I never use the high beams!
I bought a different/less expensive brand for the kids’ 2011 Altima and the results were subpar…
#64
It's why I really don't want to buy a kit. I'd rather piece meal it with stuff I know works. It's why I'm hesitant to buy a kit from RMS and he doesn't seem to want to sell just conversion headlight lenses. |
#65
That's what I'm talking about !!
#66
Whats the email address for the RMS lighting? I dont have facebook. Im assuming the 5.75 kit would be for a 70 GTO.Thanks
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
#67
This is the email that I had. Best of luck with it, I never got an answer using it.
rmslighting01@gmail.com |
#68
#69
My kit is supposed to be here tomorrow from RMS. I will install over the weekend and pst pictures.
He made a post this morning showing all the LED bulbs being gone through one by one to test them, which I thought was a nice gesture.
#70
LOL I guess the trick question to get silence is to ask him if he sells the conversion lenses separate.
#71
I installed my RMS kit today. Changing headlights is a low key hard job. Maybe there are just tricks I don’t know. I broke two of my retainers and had to weld them back together.
I’ll take a night drive later and see how improved it is if the weather cooperates.
#72
#73
The brights light up the night. Which was awesome for deer country around here. The low beams were a little lackluster initially, but honestly I think I don’t have them aimed at the road. I think they were both high. I don’t have a good spot to align them but I’m going to try and make it better than it is. I’ve asked a few shops if they have a headlight alignment machine. Nobody seems to have them anymore.
#74
Used to have a small bubble alignment attachment for headlights that would attach to the headlight via suction cups. Dealers used them all the time decades ago when I worked there. Not much use for them these days.
I've seen them on ebay from time to time. |
#75
Did it seem like your lows were aimed properly before? If they were and since you don't have to mess with the adjustments to put the new bulbs in I'd say the new leds might project higher than the originals.
#76
When I've installed the LED's I've adjusted my headlights down just a pinch. They are so much brighter than a regular bulb you simply don't need to aim them up as high. That is as long as you get a good quality LED. Some of the lesser LED's I tried didn't matter where you aimed them, they just scattered light everywhere.
#77
I also had them backwards. Brights on the outside. Fixed that this time around. So it would all be out if wack anyway.
#78
Usually pointing them at a white wall or garage door will work for aiming them, the owners manual might actually have a spec chart for aiming them with this method. It gives the distance back from the wall, and the height each beam should hit the wall.
#79
_______/
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
#80
BUT, LEDs have improved so much in the last few years I might just go that route instead as they aren't as sensitive to the voltage drop and will still put out great light. I'm definitely going to convert my Formula to LED if I can find a good kit that provides bright, well focused light and isn't ridiculously expensive.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
