Old 12-28-2017, 02:28 PM
sglemans sglemans is offline
Default Will GTO steering wheel fit 68 GP?
I have a custom sport (black rubber rim) steering wheel sitting in my garage and wondering if it will fit my 68 GP??
Old 12-28-2017, 03:37 PM
Yes
I put a sport wheel on my '77 GP
Old 01-03-2018, 02:17 PM
OK, just wanted to be sure because I thought I heard somewhere else on the web that the column from a 68 GTO would have a different diameter than the full size cars
Old 01-03-2018, 03:19 PM
Scott Thelander's Avatar
Default yes it will fit
but.........
you need a 68 collar
68 has a lip on the inside ... picture 2 and top in pic 1
69 has a lip on the outside ..... pic 3
order a 67 chrome or 68 brushed collar
and I think your good to go .....
anyone else ???
Scott
ID:	471517   Click image for larger version
ID:	471518   Click image for larger version
Old 01-03-2018, 06:23 PM
rustyrelic rustyrelic is offline
Sorry if I high-jack the thread.
Is the horn switch on the 68 GP the same as the 68 Bonneville (2 door bell style switches on the spokes)? If so, what do you do for the contact spring, contact post and turn signal cancel cam?
Old 01-03-2018, 06:30 PM
Default hijack
yes please start another thread
and supply pictures ...good pictures usually really help
Scott
Old 01-04-2018, 02:27 AM
Scott thx. So now I see the lip is for the diff. diameter. What else do I need to switch over, other than the wheel, horn button/contacts etc.?
Old 01-04-2018, 02:45 AM
Default .......
just the collar I would think
you have all your 69 stuff right ??
unless you want to make it look like a 68
then the horn button changes ..yes
Scott
Old 01-04-2018, 03:08 PM
Actually I just have the bare wheel, nothing else. The original one that's on the GP is the black plastic wheel with the clear translucent top half. Like most, the clear part is falling apart. The one I want to put on is like the 69 in the pic below, but with a black rubber rim.
Old 03-12-2018, 02:57 PM
Gastiresandoil's Avatar
https://seattle.craigslist.org/skc/p...527779062.html
