Old 12-29-2017, 04:41 PM
Choken69 Choken69 is offline
Default Valves for -67 670 heads?
Hi!
I’m about to restore my 670 heads for my -67 GP with 400 engine.
I will order some new valves from Summit but I have some thoughts...
Stock or stainless?
Seames to be some different ones to choose from at Summit. What are your experience and what do you recommend?
Old 02-09-2018, 11:01 AM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
Don't know if you ever got the heads redone yet, but I would go with stainless on the exhaust ports because those get hot from the exhaust exiting the head.
Old 02-09-2018, 11:04 AM
ponyakr's Avatar
ponyakr ponyakr is offline
Most recommend the Ferrea stainless 5000 series.
They're available from Butler, Ebay & lots of other places.
https://butlerperformance.com/c-1400...ce-valves.html
https://www.ebay.com/itm/Ferrea-Stai...!US!-1&vxp=mtr
SI also sells stainless valves. They have the hi perf type, with no O-ring groove, and the stock type, which does have the O-ring groove. According to the SI rep I talked to, the stock type exhaust valves are stainless, but the intakes are not. But, he assured me that all SI valves are 1-piece. Can't verify. Just passing on the info I was given. A once highly esteemed Pontiac engine builder used & recommended SI valves, FWIW.
http://www.sivalves.com/
http://sivalves.com/flipbook/2016-SI-Catalog.html#p=43
I assume that the engine builders here can verify which valves they think are good quality & some that are not.
