Old 01-27-2018, 04:19 PM
Dick Boneske's Avatar
Default '75 Grandville Dual Exhaust
My friend's '75 455 Grandville needs a new exhaust. We would like to change over to duals. Has anyone done this?
I've noticed that the transmission crossover mount has no bend in it to clear the left side headpipe. We've considered having someone fabricate ours to add the "bump."
Also, you may remember these cars had only about 7.5:1 compression ratio. How much can you mill the heads to increase compression? The all stock engine has only about 3,000 miles on a complete rebuild---overbore, new pistons, etc.
Name:	Dan's Grandville!.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 01-27-2018, 05:09 PM
694.1 694.1 is offline
I bet a '73 or '74 cross member would have 2 bumps. Maybe run 400 heads & advance the smog cam?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 01-28-2018, 04:48 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Yup, '74 and earlier crossmembers are dual hump more likely than not (I've got several sitting around of that vintage and all of them were, even the single exhaust cars).
As for milling the heads, I wouldn't bother. Just put a set of 6X-8s or 6X-4s on it and put an 068 cam in it and call it a day.
Old 01-28-2018, 09:07 PM
GpFreak's Avatar
GpFreak GpFreak is offline
Post Duals
I had an Impala years ago that I took to a good muffler shop to add duals. They cut the Y pipe and welded the hole shut, added the other side and flattened the pipe to clear the cross member then added glass packs. Did a great job, but man that car was loud when you got on it!
Steve Naresky
Old 01-29-2018, 09:48 PM
I have a 71 trans crossmember with the duel humps, $100 shipped to you. It has even been stripped but not primed or painted. let me know if interested
Old 01-29-2018, 11:39 PM
grandville455's Avatar
grandville455 grandville455 is offline
I’ve used Hedman shorty headers on my 74 when they first came out, was the first to use them on a b body, worked well n u could drop the engine in with them on, then later on I switched to Doug’s D 590 headers, those fit very nice too.
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 01-30-2018, 09:01 AM
I know that the 1970 GTO Ram Air III Manifolds fit the 71-76 B-Body chassis with no modifications, my 71 Police car came with them from the Factory
