Old 05-23-2020, 03:13 PM
dci dci is offline
Smile DCI Motorsports / Judes Schnabel Pump Gas 535 RA5
https://www.facebook.com/judes.schna...generic_tagged
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
Old 05-23-2020, 04:19 PM
mgarblik mgarblik is offline
Congrats on the engine's performance so far. The first thing we did when we bought a new Superflow SF-901 in 1998 was take off the hydraulic throttle control and throw it in a box never to be seen or used again. It wouldn't work right on a Q-jet either. Not enough travel. Single Holley 4bbl. is the only thing it works right on out of the box. 22 years later, and I see they never corrected the issues. They sell a retrofit kit to cable operation or you can make it yourself. Best of luck the rest of the dyno session.
Old 05-23-2020, 04:39 PM
Stan Weiss's Avatar
Since I and I am sure others are not on FaceBook. Could someone post that information here?
Stan
Pontiac Pump Gas List
Old 05-23-2020, 04:54 PM
pastry_chef's Avatar
I wonder what fuel was used or maybe an instrument issue. Less than 210 lbs/hour of fuel at peak power.. BSFC in the .2xx
Old 05-23-2020, 05:17 PM
Stan Weiss's Avatar
Mike,
I am not on FaceBook and so can not see what was posted. Can you post up the dyno sheet here?
Thanks,
Stan
Old 05-23-2020, 05:32 PM
Thanks,
Stan
Here you go.
Old 05-24-2020, 04:38 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What is an acceptable range of BSFC?
Old 05-24-2020, 04:40 PM
slowbird's Avatar
slowbird slowbird is offline
.4 to high .4 it does depend on type of gas though
Old 05-24-2020, 05:22 PM
cfmcnc cfmcnc is offline
The selector knob on the dyno for fuel turbines is in the wrong position.The numbers are half what they should be.Someone is not paying attention.Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
Old 05-24-2020, 06:44 PM
slowbird's Avatar
I said that on FB a day or 2 ago. The last sheet he posted looks much better.
Old 05-24-2020, 07:09 PM
PAUL K's Avatar
PAUL K PAUL K is offline
WOW!!!
Go fast, see Elvis!
Old 05-24-2020, 08:09 PM
I also mentioned it on the FB post ,It looks like they removed it.So much for trying to help someone ,Bill C.
The Following User Says Thank You to cfmcnc For This Useful Post:
Old 05-24-2020, 11:11 PM
slowbird's Avatar
It's there just need to look at Don's fb page
https://m.facebook.com/story.php?sto...composer=false
Old 05-25-2020, 12:22 AM
Stan Weiss's Avatar
Generally the A and B channels are pretty close to each other. For this case let double both.
215.1 * 2 = 430.2 lbs/hr
0.252 * 2 = 0.504 BSFC
Engine Size = 535.021 ci
Dyno Barometric Pressure = 29.0 - Dyno Vapor Pressure = 0.05 - Dyno Air Temperature = 75.0
STP - SAE J607 Correction Factor = 1.0483
_______STPPwr__STPTrq___BMEP_____Fuel___BSFC__UnCo rr__UnCorr_UnCorr_Correct___A/F______Air_
__RPM____CHP___Clb-ft____PSI___lbs/hr__lb/hph___HP____Torque___BMEP__Factor__Ratio____SCFM__ __VE%
_7400___904.6___642.0__181.0___430.20__.5040___853 .6___605.8__170.8__1.0597__12.75__1197.6__111.2
Stan
Old 05-25-2020, 09:27 AM
ponjohn's Avatar
Stan
Is the BSFC essentailly an indicator of efficiency?
If a BSFC is out of whack should one go back to the drawing board?
Old 05-25-2020, 10:21 AM
BSFC.Is a measurement of Pounds of fuel per Horsepower Hour.It shows how efficiently an engine is performing.For example well refined race engines will be mid to high 30s to low 40s.A Q-Jet on a dual plane will be high 40s to low .50s..Bill C.
Old 05-25-2020, 12:05 PM
John Langer's Avatar
John Langer John Langer is offline
What's up with the 30hp jump after it peaked and started to fall off 🤷*♂️
Old 05-25-2020, 12:30 PM
Originally Posted by John Langer View Post
What's up with the 30hp jump after it peaked and started to fall off ��*♂️
John ,Are you talking about the last line on the posted dyno sheet where it dumped 30HP?
Old 05-25-2020, 12:53 PM
No where it peaked at like 885 then dropped off to 870 then jumped up in hp and tq to get to 900. I've only seen that one other time.
Old 05-25-2020, 12:55 PM
slowbird's Avatar
I think John is referring to this sheet
