'65 A/C hoses/clamps
Hi All-
Is anyone making new A/C hoses? In particular the Receiver to Evaporator Hose Assembly? I have a couple old ones, would like to replace if possible. Also, both of the Freon hoses (suction and discharge)? Anything special about those kind of hoses? I've seen hardware store type clamps used on these hoses, gotta believe those are not correct! Thanks for any replies! |
I am assuming you're referring to a 1965 GTO, If so we do carry these lines under part numbers P120DE for the liquid line from receiver/dryer to the expansion valve as well as P120DH which would be the Hard line from the receiver/dryer to the condenser or you could go with our AC muffler and hose kit "P120DPB" which would include the compressor muffler w/outlets, (2) rubber ac lines with ends, POA valve fitting line & jumper tube,Liquid line jumper,suction line clamps, P120DH "AC drier to condenser" as well as the o-rings. All of these items can be found on page 247 of our G31 catalog.
Thanks for your reply, I should have mentioned '65 B-body (Catalina)
With all those selections I hope you have some for the big cars ? |
Unfortunately we do not offer hose kits for the full size cars at this time the o-rings I do have "PP199FA". But hopefully someone on here can chime in and give you a better solution. I do know Old Air Products does offer A/C hose by the foot in varies sizes. http://www.oldairproducts.com |
