Old 04-24-2024, 02:32 PM
MJZ's Avatar
MJZ MJZ is offline
Default Replace or Recover Parchment Front Bucket Seats
Mine are starting to show some wear and the support sucks. My question what is the best way to replace? I can get the recover anywhere but then I'd have to mess with the springs and replace padding. The other way of buying a good after market pair complete. What would y'all suggest?
Old 04-28-2024, 11:33 PM
KGTO's Avatar
KGTO KGTO is offline
I think you're better off rebuilding the stock seats, maybe someone else will chime in. Get the good foams and complete kit.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 04-29-2024, 07:52 PM
Rachelsdad's Avatar
I just had my seats done in my '63 Bonneville convert, with vinyl on the outer areas and leather in the seating areas. As part of the process, the upholsterer reconditioned my frames and metal springs (including sand blasting and painting, tightening, and so forth) and added new foam and cloth.
I would highly recommend finding a good shop to do essentially the same for you. Covers are one thing, but as you've already commented, the support is lousy (my back used to really complain on longer drives - even in my younger days, and even with my 6-way power seat). Talk to the shop, explain your support concerns, and let the upholsterer show you what types of foam would be options for you.
HTH
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
Old 04-29-2024, 07:56 PM
MJZ's Avatar
MJZ MJZ is offline
Sounds like good advice, thank you.
Old 04-29-2024, 08:51 PM
Rachelsdad's Avatar
You bet. Let is know how you make out!
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
