Old 01-16-2020, 12:47 AM
Dragncar Dragncar is offline
Default electric fan ? HP difference
What are they worth on a dyno ? I have a electric fan but not sure if I want to use it on the 461.
I have the fan and a V pump but thinking about going with a normal fan and header E vac for the little engine and saving the electric fan and V pump for the 540 IA2 engine.
Time reasons as much as anything. April will be here quick and I would like to make the first race. I might gyno the 461 if I can swing it.
Old 01-16-2020, 07:29 AM
Related.....
https://forums.maxperformanceinc.com...=electric+fans
Old information here:
Old 01-16-2020, 09:17 AM
Primary purpose for Elec Fan is Reliability, not HP or better/worse cooling comparisons.
I cracked-out an Iron Waterpump on the Highway during a 2-3 upshift.
In-town Chevy guy launceh his Mech fan through hid hood at Maple Grove at the Tree.
Since then, no biggie Mech fan, and primary cooling is passive through the Radiator, with the electric fan used during peak heating (lights, Summer highway, long idling).
Old 01-16-2020, 02:46 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Originally Posted by Dragncar View Post
........I might gyno the 461 if I can swing it.
What does than involve, exactly????
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 01-16-2020, 04:39 PM
AG's Avatar
AG AG is offline
Jim
A doctor.
Old 01-16-2020, 06:34 PM
Mike Davis's Avatar
Jim
Something fishy!
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-17-2020, 05:34 AM
TheGrudge TheGrudge is offline
Something to do with inspecting a bore?
The Following User Says Thank You to TheGrudge For This Useful Post:
Old 01-18-2020, 11:07 AM
firechickenman's Avatar
firechickenman firechickenman is offline
Engine Masters had an episode where they tested belt driven fan hp loss on a dyno. They tested on a 350 hp (with no fan) SBC and the best fan was an OE clutch fan that killed 14 hp at 5200 rpm. I would assume hp loss would be greater on an engine turning higher rpm.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 01-18-2020, 05:22 PM
14 HP of drag during acceleration is asking for a broken water pump, pulley, or lunching the fan loose.
Old 01-18-2020, 05:36 PM
A friend with a very consistent bracket car cycles elec pump & fan between rounds to control temps -( I’m sure he’s not the only one) he swears by it.
Old 01-19-2020, 08:09 PM
Its something for me to think about. There have been several days where I made it deep in Super Pro and Pro. Finals in both once or twice with the car getting little time to cool down. Just stopped off to get a little gas and back to the line.
But I think I would need a generator running in my pit to do it. I would like to avoid that if possible. There are a couple pits that have electricity right there but my pit is the first one form the starting line right on the rail. Its great for family and friends watching and hanging out.
Old 01-19-2020, 08:19 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is online now
I doubt you would need a generator as long as you run an alternator. I use an electric water pump and fans between rounds. Run the fans a couple minutes between passes and its good. Only an issue when I walked away and forgot to turn off. 25 minutes later I needed a jump start..lol..
Old 01-19-2020, 09:34 PM
I run a little 36 amp alternator. Heck, the car even still has a power steering pump. 10s.
The pump went bad so I don't run it anymore but I did try it with the belt on and off back when it worked , no ET or MPH difference in my case.
Old 01-19-2020, 09:46 PM
AIR RAM AIR RAM is offline
On average I have seen a gain of 10-12HP GAIN when removing the clutch fan and installing an E-Fan. However its difficult to beat the reliability of a clutch fan... in the end you have to decide how bad you really need that 10-12HP gain... I personally just like the cleaner look with an e-fan so I do it more for looks than the power gain.
With all that said, I have been really considering using a clutch fan on my current 496 build... reliable street ability is priority on this build.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 01-19-2020, 10:37 PM
SPEED SAFE, NICK
The fan I have used for years is one of those cheap solid plastic ones. They weigh nothing, have a 8K limit which I will never see and cool great.
Old 01-19-2020, 11:39 PM
If it's one like this, it cost 25 hp at 5100 rpm in the Engine Masters test.
https://www.summitracing.com/parts/f...oaAj1AEALw_wcB
'68 Firebird
The Following User Says Thank You to firechickenman For This Useful Post:
Old 01-20-2020, 02:36 AM
That is the one, looks like a electric fan would take me from 10.83 down to 10.75 or so. Its a bracket car so I don't care about a little power loss, as long as it is consistent and stays cool. I never throw belts and get by with a puny alternator and it cools great.
What are some good clutch fans suitable for racing ? 18"
Old 01-20-2020, 09:54 PM
I've been running an OE fan with Hayden thermal clutch for the last 6 seasons without issue. That said, I think a clutch fan is probably the least consistent fan type. Coolant and ambient temps can change how much it is engaged and that would change the HP it takes to drive it. A fixed fan will take more HP to drive it, but it will be the same every time. I think electric would be the most consistent with the ability to control engine temps better than either of the two belt driven designs. Electric is also the safest fan for racing. Not much chance of it coming apart and sending parts flying.
'68 Firebird
Old 01-20-2020, 10:33 PM
Ahh yea, the time when the clutch fan locks while your accelerating, nothing like it.
Went through 3 clutch fans that each locked-up solid when failed. Na, nope, no more.
Old 01-21-2020, 07:22 PM
69MaizBird 69MaizBird is offline
E fans are a no brainer. No way I'd risk a fan at 7300. Also with an e water pump it cools in the pits very efficiently without bumping the motor to circulate water. There are very few autos that use mechanical fans these days and it is because it is more reliable and efficient to run electric.
