Old 08-04-2015, 07:23 PM
Robert C.'s Avatar
Robert C. Robert C. is offline
Default Question: When is a block no longer a corporate block?
Please don't take this to the dark side.
You see these TV street racers claiming 700.C.I. with spread bores, stretch Hemi crankshafts, Hemi Rods, Cam lobes moved, custom cam chains. Billet Aluminum blocks with No Water Jackets and Billet Heads claiming is a Chevy. They can't bolt a stock cylinder head to it and start the motor on a bet.
Or is it a more of a experimental motor? And should be called just that.
Thoughts?
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 6.027@231.64
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 08-04-2015, 07:38 PM
70 bird's Avatar
70 bird 70 bird is offline
Pontiac people seem to have self imposed bore spacing constraints.
Old 08-04-2015, 08:05 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
If I had the money I would stretch a pontiac block, crank and tiger heads to 1000 ci. and still call it a Pontiac. It would probably be a tri-power with 3- 4 bbl carbs so it looks right.
Steve
Old 08-04-2015, 08:13 PM
mgarblik mgarblik is offline
Your question has been thrashed around on the board for years with no real consensus. Anybody can say and claim anything from a corporate Big Block being or not being a Pontiac to an LS engine being a corporate engine to a Chevy engine, the list is almost endless. Even the serious Pontiac racers have hard and fast rules they live by, but are all different. To me personally, if the engine is somehow recognizable as a Pontiac V-8, I accept it as such, but who am I? As far as what I am willing to race and personally claim as a Pontiac, my answer is different. My rules for a Pontiac engine are: 1. stock bore spacing. 2. 10 head bolts 3. a cylinder head of a general design engineered by Pontiac. That's why the Grocery Getter and Boss Bird engines look like they do. My rules. I have no problem with others with their CV-1's and warp canted valve heads, spread bore spacing and 18 head bolts. It's just not for me, not quite "genuine enough" for my taste.
Old 08-04-2015, 08:14 PM
Travis Q Travis Q is offline
Here's a question in response to your question:
If an enterprising person had the means to make a 'Pontiac' block that was, say, 4.840 bore spacing (factory BBC bore space), utilized a BBC crankshaft, used a BBC camshaft height (so a BBC timing chain could be used), but yet kept a Pontiac appearing front timing cover arrangement, used a head stud layout that looked like the factory Pontiac layout, and kept all the other quirks that make a Pontiac look like a Pontiac (pass side cyl head forward, valley tray, distributor in rear, etc)........
Would anyone ever notice?
Other than a VERY small number of engine builders, I seriously doubt it. To everyone else, it would still be a 'Pontiac'.
gene simmons gene simmons is offline
When the exterior of the block no longer resembles the original.
Old 08-04-2015, 08:22 PM
Why not 5" bore space?
Old 08-04-2015, 08:27 PM
krisr's Avatar
krisr krisr is offline
4.840" bore spacer would be smarter/appealing because;
Would save a heap of cash.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 08-04-2015, 08:30 PM
GREATGTO's Avatar
GREATGTO GREATGTO is offline
Pontiac racers may want bigger engines, but what everyone else needs is a short deck pontiac block. Like I said before these old cars are getting harder and harder to find and when you do find one at a decent price its needs everything.
The block needs to be able to fit into 3rd and 4th gen firebirds and trans ams since those are the only rear wheel drive pontiacs left that can be bought very cheap.
The people who drive their old pontiacs are perfectly happy with what they have, no changing those people.
You want to start a new market and sell blocks just build a 4th gen firebird with a new short deck block. Build a street friendly car that anyone can build at an affordable price.
You have to bring younger people into the pontiac hobby or its dead. Once the younger people see what can be done with a traditional style pontiac short deck block you can spring the big stretched blocks on them later, they are more open than the old timers on these forums. Destroy some LS engines on the street and track they will catch on.
This is just my opinion
Car Craft Garage.
Automotive Restoration
Old 08-04-2015, 08:31 PM
John Langer's Avatar
John Langer John Langer is offline
I actually kicked that idea around 7-8 years ago. Cfe came to me and told me they could stretch a tiger head to fit a bbc block and no one would have known the difference... If you put a cfe 4.600 sb head on a pontiac block, would it be a sb or pontiac???
Old 08-04-2015, 08:42 PM
GREATGTO's Avatar
I have a friend who used to restore vintage cadillacs, business was great until all his clients died. Pontiacs need a youth movement and in a hurry.
Car Craft Garage.
Old 08-04-2015, 08:50 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
It's a great question and a tough call. I reckon it depends on the use of the answer provided. In my mind if it's a 10.23" deck or shorter with a stamped valley cover and die cast Pontiac front cover/water pump then it's ok. 5" bore centers are acceptable in my mind. A 4.84" bore center would allow common BBC cranks to be used for cost. The bottom line is it's looks like a Pontiac then it's ok.
Are these experimental engines? Hardly, it's just new geometry on 70 year old architecture in my mind.
Old 08-04-2015, 09:00 PM
Tom Vaught's Avatar
Boost Engineer
There is no such thing as a Pontiac "Corporate Block" any longer. Same deal with the Oldsmobile "Corporate Block". General Motors Killed both Divisions. There is no 'living parent' (except for the 3rd/4th gen type vehicles with the Chevrolet "Corporate Block".
So you are basically playing with "Historical Blocks" (same deal as the other manufacturers that folded/died).
For the Engine to be a "Historical Engine" it has to have the basic items Mike G.
So Bob, Pontiac stopped racing (as a Corporation Division) in the early 60s.
So you can't call it a Race Block, or a Corporate Block, but might get away with a AFTERMARKET "Historical Engine" block, crank, heads, etc.
Tom V.
Old 08-04-2015, 09:08 PM
67GTO4SPEED's Avatar
67GTO4SPEED 67GTO4SPEED is offline
As great of an idea as this is, unfortunately I think it would catch a lot of grief from none other than the traditionalist Pontiac community. I hate to say that, but I have been building and working on cars all my life, and I've never seen the division that there seems to be in the Pontiac world. I think the guys that were unwilling to run it (and a lot that simply couldn't afford it) would be it's main detractors.
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners
'78 Lemans - Drag car project
Old 08-04-2015, 09:12 PM
Talk to some olds people. They make us look like one big happy family.
Old 08-04-2015, 09:17 PM
Tom V.
I don't really see the relevance of that. The BBC, SBC, BBF, RB Mopar, etc, etc. is just as dead as the Pontiac or Olds from a production standpoint. GM still makes SBC and BBC crate engines, but they are all obsolete engine designs and are a thing of the past. None of them have came in a vehicle from the factory in quite some time. The designs are getting older every year.
The difference in Chevy guys and Pontiac guys is that most Chevy guys don't really care if you modify the historical parameters of their obsolete engines if it makes them go faster. They've been doing it a loooong time too...
http://www.hotrod.com/how-to/engine/...evy-big-block/
Old 08-04-2015, 09:18 PM
T Syron's Avatar
T Syron T Syron is offline
Hahaha!!! Very True!
Tom Syron
Really? I didn't know that. Good to know there's somebody out there more dysfunctional than us!
Old 08-04-2015, 09:25 PM
Wow. I find it hard to believe there is more in fighting anywhere other than in the Pontiac community.
There's just not enough of us Pontiac people left to tolerate it. The in fighting is driving people away any we're not bringing in new young people which means it dies in the near future.
It's no wonder people moving elsewhere. I know we all like to give Marcella crap for running something else but has anyone looked at the LS architecture? There are some things to be learned there. Any high revving Pontiac has bearing and feed systems that look like an LS. I like them.
Old 08-04-2015, 09:30 PM
I like them too, but I'm not putting in my dadgum Pontiac!
