Cometics
How many guys are spraying new gaskets and are you taking them
Apart and spraying the middle layers? Have you seen a difference with or without? I have sprayed and reused old gaskets, but have not sprayed new gaskets. Thanks
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
The Following User Says Thank You to mysticmissle For This Useful Post: | ||
I just spray a light coating of copper coat concentrating around the water holes on each side.
John you’re not dry decked? You don’t bother to split them
I am not dry decked. I don’t like dry decking. We need as much coolant passing thru the surfaces as possible to address the heat problem at the center exhaust valves. Dry decking just creates more heat on the surfaces. Now on a boosted application on alcohol, I would dry deck. I just spray the surfaces for water leaks. Just want them to seal to the decks. I see no reason to spray between the layers.
I sprayed them in between like you were saying.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
I run them "as is" out of the box. If they look good on the first freshen up I spray them with Copper coat and use them a second time.
If you dry deck and use a reverse cooling system, the heads will actually get cooler water running through them, as it's come straight from the radiator and not pre-heated up from the block. If you want cooler running exhaust valves (and who doesn't?), then send your cooled water from the pump into the front of the heads at the exhaust side, (where the core /cup plug is on factory heads) and take it out of the heads at the rear on the exhaust side - this forces the majority of the coolant down the exhaust side water passages.
No need to spray them. Ive called cometic on this . They say do not spry them. Ive sprayed them before. All it does is make more clean up to reuse them . It is a good idea to spray around the water holes but i dont. There designed to be used dry. Dont waste your time spraying inbetween the layers.. 44 psi and i have no issues with them installed dry ..
My Half AN Injun..... |
Maybe a six cylinder turbo application but for a nitrous guy with a V8 it's not a waste time something you have no experience with so your comments only apply to you.. Its not apples to apples .. |
I dont have a 6 cylinder . I have a 4 cylinder. Its half of a 389 v 8 engine . Im making 900 hp with 4 cylinders . Why would it not be apples to apples?? What does half of your motor make?? Its the same as half of YOUR engine but with a smaller bore and stroke. Theres alot going on in my cylinders. My head gasket would fit your engine . Its the same thing .. I have a 461 on spray so how do i not know what im talking about ?? Also , Why dont you call Cometic and ask there tech guy if you should spray your gasket or not before you embarrass yourself more... Have a great day ...
not to get in the middle of you guys, and i appreciate everyone's input. The reason I asked is because my block vendor recommends spraying all layers of the gaskets even when new. so they have alot of experience, as does Langer and Lil Jack. there is probably more than one way to skin a cat. And cometic is not going to recommend drilling the rivots out of their gaskets as one you are more likley to mess something up putting them back on and it also implies the design is flawed.
again thanks for your input everyone
If Cometic says not to and the block vendor says to . Whos is really right?
I would say if they are worse for it. It’s not cometics fault. Right? Lots of manufactured parts are better with a few tweaks. I do not know if there is a difference but I just might try it. The last set went on dry. I’ll have a true a b first hand experience
I have a question about your 4 cylinder. Are the cranks standard cranks with some sort of spacer where the other rod would go or are the cranks made for one rod journal only ? |
If you want i can text you a picture of one .
Sure, I like to see it. 900HP out of 4 cylinders is actually amazing. Marty P was getting 1600HP out of his twin turbo 400. Not 1800 so 900 out of a 4banger is no small feat.
Good luck . I hope it works for you..
Shoot me a pm with a number and ill get it over to you..
