#161
Exact sales figures aren't available but it's encouraging to me that a moderate number of the solid blocks are out in the world now. It provides a lower cost alternative to billet and we've proven that it can handle 3000-ish horsepower in an alcohol or nitro application.
Hats off to AP for providing options for the Pontiac world! Eric
The Following User Says Thank You to Elarson For This Useful Post: | ||
#162
And then there's stan....
#163
Steve,
Would you happen to know the difference in weight between the Solid aluminum IA2 block and your billet block? Stan
#164
SD |
#165
Steve,
Thanks. Based 40 lbs difference and water at 8.34 lbs gallon and using 2.7 as the Specific gravity of aluminum, That would have the water block holding about 7 quarts of water. Does any one know how much water the block does holds? Stan
#166
Nice looking 1968 Firebird, congrats to you and your son!
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#167
Here is the weight of the IA 2 A solid block if that helps with your calculations.
#168
I know in your case you have the solid blocks so its not about your heads. |
#169
How much power does Ryan's big inch twin turbo 481X have vs Justins little 488 with E heads and twin turbos ?
#170
GTO George |
#172
Stan
#173
Tommy's car is great. But its a Pontiac block with BBCish heads on it. Not my cup of tea. RAIV and RAV heads are, even if there is no pushrod in the port. To me, Daves heads are something that would have happened in PMD if Pontiac had been allowed to compete with Chevy and not gotten screwed over tying our hands behind our backs so to speak. Had PMD been going balls out from 1970 to 1990 a lot of things would be different. The stuff that die hard Pontiac fans are doing on their own dime is nothing more than what could have been done by PMD. We are crazy but cooler than everyone else. |
#174
If PMD kept developing race related parts they would've ended up at a Warp6 style head. I highly doubt they would've persuade the RA5 head very far at all. Just like Ford didn't.
#175
They were looking at 3 valve designs.
Stan
#176
In the mid 60s.
The 1970 SOHC Hemi prototype was another direction. The 73-74 455 SDengines are actually what was left of PMDs attempt to build a LS6 street killer 10-1 455. Dan had his hands a one of 2 sets of #96 casting 455 heads. 10-1, same ports as the 73-74 heads down to the pushrod tubes. RAIV valvetrain with 4 bolt block, forged rods and pistons. around 90cc. Chevy stopped it and other programs because the Vett had to be the fastest GM car. The Opal GTs were a Pontiac car. The bulge in the hood was from the inline 6 they had. Had plans for a T ram 2x4 428 with RAV heads and forged crank. Pontiac had big ideas for performance. We are keeping up with the tradition. |
#177
If the RAV program was not squashed I do nt see why they could not have went the way Dave is right now. That head still has Pontiac valve cover, RAV ex and cam, inline. Its pretty close to a Pontiac head in a lot of ways. It will be awesome to see how far it can be pushed. |
#178
GTO George |
#179
GTO George |
#180
Your number 2 till your faster than number one George. It's that simple. What could and should be have not happened. Tommy's car is a work of art with all the current technology. It got wrecked like many do trying to get to the front. May get wrecked again on that journey. Smart persistent people like Langer for instance keep going and accept seatbacks for what they are. I think Tommy's group has the same attitude. He will be very fast at some point just not today
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
