Old 01-19-2020, 10:43 PM
Scott Roberts Scott Roberts is offline
T-bar clamps
Did you use a fore/aft bars?
(had to have the blow back bars)
Mid plate was 3/8 aluminum bolted solid to the frame, front held down with saddles and T-bar clamps...
No blow back pins.
Old 01-19-2020, 11:57 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
My car has a smith race craft front end with 1/4" motor and mid plates with trans bolted directly to trans crossmember no mount. No engine limiter. No issues.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 01-20-2020, 11:19 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
I guess i was more worried about the load from the mount bracket on the side of the block than anything. My current set up is an old style Hurst engine mount that still bolts to side of block and comes forward and has an additional strap that comes up to the head. These pics arent mine but shows how it is installed. I run the front section solid to the frame.
ID:	529235   Click image for larger version
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 01-20-2020, 12:42 PM
chiefbigb chiefbigb is offline
I dont see where it would hurt to have limiters. I have run cars with and without. I have seen some bent up mid plates also. How well everything is constructed and where it mounts to the frame means allot
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 01-20-2020, 01:50 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
I wouldn't use the factory mounts or the bosses in the block, especially for racing. I think it puts too much stress on the side, possibly contributing to blocks cracking. Remember, this is the RACE section.
My new 10.0 combo will have a 1/4" Aluminum engine plate BEHIND the timing cover, 1/8" steel midplate from S&W and a poly trans mount. No engine limiters.
But for those of you that use limiters, like someone else said, it can't hurt (unless it is binding, somehow).
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
