Old 01-23-2020, 08:31 PM
John V. John V. is offline
Default 2nd gen 4 spd parts wanted
Looking for a 5615 Shift Arm (have one, need a 2nd).
Also need a 5616 Shift Arm (for reverse).
I am also looking for a Reverse Lockout Linkage for a '73 4 spd.
These items are at the top of my list but if you have other 4 spd parts for a '73, let me know.
I have the Muncie trans, shifter with shift rods, and the pedal set but everything else was removed and missing.
Trying to avoid going with repro stuff, would like to use original parts if possible.
Old 01-24-2020, 08:08 PM
FASTASSBIRD FASTASSBIRD is offline
Look for. 73 Camaro ITM shifter on eBay. Most likely to find a shifter with rods for 250ish. The rods are the hardest part. Should be able to sell the shifter back on eBay.
Old 01-24-2020, 10:21 PM
Thanks but I have the Hurst Shifter with correct rods already.
The 5615 and 5616 are Shift Arms, the small tabs that the rods attach to. Camaros with the Muncie used the same tabs. They show up on ebay on occasion but so far I have seen them too late when offered.
Old 01-25-2020, 04:29 PM
Held for Ransom's Avatar
Contact Eric (member crashent) and see what he may have.
So long, farewell.
