Old 01-09-2014, 11:02 PM
blue71ta's Avatar
blue71ta blue71ta is offline
Default 1970 455 HO production numbers?
anyone know how many '70 GPs came with the 455 engine?
Old 01-09-2014, 11:55 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
There were 68,750 GP's produced for 1970. Of those, 12.5% came with the 455 engine. I don't know if there is an actual number.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 01-10-2014, 09:39 AM
blue71ta's Avatar
Thumbs up thanks
So approx 8,600 with the 455 then.
Old 01-10-2014, 11:00 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Used to have a 4 speed coded 70 GP HO block..pretty rare
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
Old 01-10-2014, 12:29 PM
Old Goat Racer's Avatar
I have a '70 455 HO block. But the car is long gone.
Everybody knows somthin.
Nobody knows everything !
Old 01-12-2014, 01:15 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Default 8250, from a 2006 article in HPP...
1970
Given the success of the '69 Grand Prix, Pontiac would have been foolish to change much for 1970. With that in mind, exterior updates were limited to smaller details such as grille and taillight textures, and the repositioning of exterior trim. The interior was essentially carried over, but a bench seat was now available as a credit option, and only with the Turbo 400.
The 350hp 400 four-barrel was again the standard engine in the Model J, while the low-compression 400 two-barrel remained a no-cost option. The 428 engine from 1969 grew even larger for 1970. An increase in crankshaft stroke from 4.00-inches to 4.21 caused displacement to jump nearly 30 ci to 455. Although referred to in sales literature as "455 H.O.," the new 455 was similar to the 428 H.O. it replaced, but lacked the high-flow exhaust manifolds, and was subsequently rated at 370 hp. Transmission usage remained the same for each application.
An economic recession during this time had many new-car buyers searching for less-expensive models. And since most Pontiac offerings were slightly higher priced, Pontiac had fallen as far back as sixth in sales during the '70 model year. Grand Prix production not only reflected this, but it was also impacted by the competitive models being offered by other manufacturers. Total production fell to nearly half that in 1969 with just 65,750 units produced. The Model J represented 60,165 of that total while the remaining 5,585 units were SJs. Pontiac's 455 four-barrel engine was installed in 2,665 Grand Prix Model Js at a cost of $58. And manual transmission-equipped Grand Prixs totaled just 500 units.
The Following 2 Users Say Thank You to 428ho4spd For This Useful Post:
Old 01-12-2014, 08:49 PM
blue71ta's Avatar
Great, thanks for the info
Old 01-13-2014, 01:06 AM
Pontiyak's Avatar
Pontiyak Pontiyak is offline
Grant, do you know the breakdown for J and SJ in 1969 ?
Thanx Dave
Old 01-13-2014, 10:42 AM
428ho4spd's Avatar
Default 11,083 SJ's for '69...
Dave, here's a link to the full article with more production numbers for '69 to '72 GP's.
http://www.highperformancepontiac.co...ac_grand_prix/
Grant
Old 01-15-2014, 05:54 PM
Didn't even notice I typed in the wrong total. Thanks for the updates.
Old 01-15-2014, 06:58 PM
Know where there is a secluded yard with several builder '69 & 70 GP's. All have been in the sell as a whole vehicle area for nearly 30 years & the hail storms have pretty much done their damage. One of the long setting '70's has SJ trim, yet it has a 400 2bbl with an 8.2 Pontiac 10 bolt. I've popped the hood & jacked up under the rear & its stock. Have had a bunch of '69-71 SJ GP's, a few '70 455 J's, & own a 428HO '69 model J. Have looked at thousand more, & have never ran across such a deal on a '69 or 70 SJ. Do not have access to '70 GP order sheets, was there a economy engine choice, like in previous years, an engine option that would have been a credit on the invoice? TIA
Old 01-15-2014, 07:40 PM
428ho4spd's Avatar
WOW, I'd like to see that yard! Any stick shift cars in the bunch?
Maybe someone put the SJ emblems on it, or swapped out the 455 and 12 bolt rear. Yes, in '69 & '70 you could opt for the 400 2bbl, but I believe it was only available on the Model J as no extra cost option. All of the 2bbl GP's I've seen (a handful) were Model J's.
I'd like to hear more about your '69 HO car, colors... options? Photos!
Grant
Old 01-18-2014, 02:37 AM
Pontiyak's Avatar
I too would like to hear of this yard.
As well on info on your HO cars.
Dave
