Old 03-19-2012, 05:07 PM
1963409 1963409 is offline
Default 62 GP Hurst Shifter ( w/center console)
I know this has been discussed before, but on a 62 GP with console has anyone installed the Hurst shifter 3917308? It's the only shifter for 62 GP with BW transmission, It states w/o console. Has anyone used this shifter with a 62 GP w/console? Does it work and fabrication needed?
Old 03-19-2012, 07:14 PM
Stuart's Avatar
Stuart Stuart is offline
This is the 3917308 shifter installed in my bench seat '61 Bonneville:
As far as I know, the shifter on a bucket seat car sticks up through the floor in the same spot, the differences are the shape of the shift porch and the shape of the lever itself (the stock lever on bucket seat cars is straighter.)
This is a bucket seat porch:
These are bench seat porches:
Old 03-19-2012, 08:45 PM
Engine-Ear's Avatar
Exclamation Hmm...
Can you clarify this? Also WHO (what documentation?) said it's the ONLY shifter w/ BW transmission... the only HURST shifter or the ONLY shifter? Only, be it at the final assembly plant or dealer or anywhere or...?
Old 03-20-2012, 01:21 PM
Pontiac62's Avatar
Pontiac62 Pontiac62 is offline
Here is the instruction sheet from the original Hurst shifter that I installed in my GP in the 60s. It shows the shape of the handle.
Old 03-21-2012, 06:45 PM
Thanks for posting instructions from Hurst. When I contacted Hurst, they told me that the shifter 3917308 is the only one they have listed for 62 GP that they make today. On the listing it states w/o console. No one at Hurst could tell me what the difference is, or what if/any modifications need to be made to make 3917308 work in my car.
Old 03-21-2012, 07:07 PM
Pontiac62's Avatar
Sadly, I no longer have that car, and the shifter went with it. But I do recall that the shifter was curved, not straight. And I also believe that it was not bent to the side. I'm wondering if the overall length of the handle was different.
Does anyone know if the seat height is different between the bench and buckets?
At least I kept the original GM shifter and have it on the car I have now.
Old 03-21-2012, 09:24 PM
ho421's Avatar
ho421 ho421 is offline
where is the part number located on the shifter. I just purchased one from a fellow py member a couple months back and he said it came from a 62gp w/console he once owned.
Old 03-21-2012, 09:36 PM
real61ss's Avatar
real61ss real61ss is offline
The number is stamped on the left side of the shifter body
Tommy's Early Muscle Cars
1959 Pontiac Catalina Sport Coupe 3x2 3 speed manual
1960 Pontiac Ventura 425A / 4 speed
1961 Pontiac Catalina Tri Power / 4 speed
1961 Ford Starliner 390 / 401/ 4 speed
1962 Corvette 327/300 / 4 speed
1962 Gran Prix Tri Power / 4 speed
1963 Pontiac Catalina 421/ 4 speed
1964 Pontiac Catalina 3x2 / 4 speed
Old 03-21-2012, 09:39 PM
real61ss's Avatar
The shifter from my '62 Cat is a 427092. It's the old one piece style Hurst (not the bolt on handle)
Old 03-21-2012, 10:44 PM
ho421's Avatar
this one is 3216274 that is all that is stamped on side by pat pend. front side has 2083. has 2223 adaptor for t10. shifter arm looks to have about a 10 degree angle. it has the bolt on arm.
Name:	hurst comp plus.jpg
