Old 09-15-2013, 02:44 PM
1963409 1963409 is offline
Default 62 GP- headlight grounding location
Finally getting together front end, grilles and lights together. I have new wiring harness, I cannot see factory ground location for headlights. Is there a hole in core support? I cannot seem to find a hole within reach of harness that would make sense. Any photos or advise would be helpful- Mark
Old 09-15-2013, 08:20 PM
Derbs24's Avatar
Derbs24 Derbs24 is offline
Here ya go, 3 pictures. 1.My '62 Prix. 2.The Passenger front showing the front corner where the headlights are. 3.A close up of the area directly behind the headlight where each headlight runs a separate ground wire with an eyelet into a tek screw, into the core support (just like you thought!).
Each headlight has a separate black wire coming right out of the headlight plug and going directly to this tek screw behind the headlights.
Hope this helps!
Jason (Derbs24)
ID:	336884   Click image for larger version
ID:	336886   Click image for larger version
Old 09-15-2013, 08:50 PM
Thanks for the picture, I bought this car in pieces, and did not have opportunity to take apart. Here is as far as I got today, of course, I need to go back an attach grounds tomorrow then put on front bumper. Thanks for the help. Turning out to be a 7 year project that I probably did not need.
Old 09-15-2013, 09:04 PM
Derbs24's Avatar
Nice car, looks like we have twins! You're on the home stretch. My car took 28 years to complete (my Dad started the restoration, I finished it) so I know what you're going through, but it's all going to be worth it. Give me a PM anytime you need pics or anything else. Jason
