Old 07-06-2021, 08:16 PM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
Default 63 GP turn signal switch?
fired up the GP on saturday and was checking all the lights. turned on right turn signal and front and back worked. went to switch to left and right stayed on. doesn't seem to do anything when moving lever. any ideas where to start? i do not see any switches or parts listed in ames catalog for 63. btw its a tilt column if makes any difference. thanks
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 07-07-2021, 08:47 AM
jamesq's Avatar
jamesq jamesq is offline
Here is a current ebay listing for a switch that the seller says fits a 63 GP w/tilt:
https://www.ebay.com/itm/20291466153...EAAOSwSypY-W8~
There are a couple of NOS switches listed as well for 3x his price.
I have not dealt with the seller,
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
Old 07-07-2021, 12:59 PM
webfoot's Avatar
webfoot webfoot is offline
I got a switch from this seller for my 62, the bracket looks like it is a nice original, and the plastic housing looks NOS and the spade terminals are brand new. I have to send my bracket back to get a $50 core back so I found it very reasonable price wise.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 07-07-2021, 07:09 PM
stevep's Avatar
stevep stevep is offline
63-65 B body Pontiac Tilt switch switch should be the same. Not sure about other makes.
Old 07-07-2021, 09:19 PM
61 389-348's Avatar
61 389-348 61 389-348 is offline
There's a wire cable next to the steering column that falls off the switch. Just climb under there and put it back on. No tools needed.
Old 07-08-2021, 07:49 PM
61 389-348's Avatar
cable usually falls off of this
https://photos.app.goo.gl/MUJ4Jtiivx1jb7en8
Old 07-08-2021, 08:22 PM
Jim Zeek's Avatar
i'm starting to think it has to do with cable. i'll look into it more tomorrow. thanks guys
Old 07-08-2021, 08:25 PM
Jim Zeek's Avatar
i'm also guessing this is not automatic cancelling?
Old 07-08-2021, 08:34 PM
61 389-348's Avatar
The cable just slips off the black pin as I have circled in red. I put it back on mine about every six months. Takes less than 5 min.
Old 07-09-2021, 08:34 PM
Jim Zeek's Avatar
cable was off. i put it back on but when i went to try it only left came on. have to figure out how to adjust it. you would think they would have had a better way to attach it. thanks for the help
Old 07-09-2021, 10:58 PM
61 389-348's Avatar
Can't help there. When I put mine back on, both sides work until it slips off again. Happens every 6 months to a year.
Old 07-10-2021, 11:45 AM
webfoot's Avatar
Wonder if you could put one of those inner tooth lock washers on it, the kind that hold the heater cables to the actuator in most cars. Forget the technical name.
-Jeremy
Old 07-10-2021, 07:22 PM
mgarblik mgarblik is offline
I would operate the switch with your finger on the switch post first with the cable off. If both right and left work, it has to be the cable, lever, or some adjustment. If it doesn't work on both sides, the switch contacts themselves are the problem, or the sockets and bulbs, or wiring/connector to the switch. As far as keeping the cable on the switch post, I would push a tinermans clip over the post to keep the cable from falling off.
Old 07-10-2021, 07:42 PM
stevep's Avatar
That is what they had. They call them a fingered speed nut
Old 07-11-2021, 12:44 PM
61 389-348's Avatar
"tinermans clip"
I should also do that. It just doesn't come off often enough that it really warranted doing anything with it. That's an easy fix though.
