Master Cylinder color?
On a non power brake 70 Judge what color is the master?
Thanks, Joe
1966 GTO Conv't, 4-speed, Tri-Power(sold) 1967 GTO Ram Air, PHS Doc. 4sp, #'s match, 15+ options 1 of 751 (Featured on Cover plus 6 page spread in May 2006 HPP) 1970 GTO Judge, PHS Doc. 4sp, #'s match, Ram Air III 2006 GTO Spice Red. M6,18" wheels, 400 HP LS2 richmondcountypontiac.com Need High Quality Printing fast and reasonable? www.farbetterprinting.com Since 1974 Quotes at: sales@farbetterprinting.com |
cast iron
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored) 1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505 1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS AC Cobra Kit Car 521 670 HP/715 Trq LOOKING FOR V PARTS !!!!!!!!!!!! |
The master cylinder was painted black on all the cars. The MC casting was painted black then got machined and assembled. So the body was black and all the machined surfaces were bare metal. This is pictured in the accesory guide for each year car - in the 69 it shows a picture of power brakes and it is clear the mc is black and so are the calipers and many other cast iron parts that had been machined
hmmmmmmmmmmmmmm
Mine is painted black, and have been told by multiple judges that either is correct. Was told by Sawruk that his feeling is that black is correct, but the supplier finished the raw steel and put a water based black coating that easily came off.
Similar to the emissions sticker controversy on 69's. The emmission sticker on top of the radiator support is correct. However, they were tissue paper water based stick ons, and most of them were gone by delivery. |
FWIW this information is out of the 1970 Pontiac Factory Service manual, I can't speak for 1969, but they use the oval body (different all together). Also I'm not saying this is absolutely correct for all, just pointing out what I have found.
In the 1970 manual they show a few Master Cylinders. One for "Standard Brakes", another "Delco Maraine Power Brake", and a third "Bendix Power Brake". What is interesting is the manual states "The Bendix power brake unit can be identified by its all-black color and external piston stop screw on the master cylinder". This Bendix M/C is easy to identify as you can easilly see the secondary pistion stop set screw in the middle of the the very bottom of the M/C. Personally I don't know if these were even used, or how commom they are on GTO's. I have an early 70 GTO and a mid 70 GTO and both use the Delco Moraine Power Brake Units. They can be identified by having the secondary pistion stop screw located in the bottom of the front fluid reservoir. It mentions nothing about the color so I assume it doesn't have any, meaning natural cast iron. Also note that the Standard Brake M/C also has no mention of color in the service manual, and it looks very close to the Delco-Moraine Power Unit also with its secondary piston stop screw located in the front fluid resevoir. So in a nut shell according to the Factory Service Manual only the bedix type M/C should be black. In any case I am restoring my Judge (with it's Delco-Maraine Unit) cast iron color. Also in speaking with the original owner whom I bought the car from, he didn't recall the M/C being black when he bought it new, and in fact thought it was unpainted cast. |
The 10A Pontiac Assembly 70 Judge Conv I painted had the original MC and it was Cast iron, errrr I mean surface rusted...
Survivors, frameoffs etc http://community.webshots.com/user/firstgenaddict 68 GTO HO 4spd Alpine Blue over Parchment headrest (paused while I restore other people's cars) 70 Judge Conv. RAIII 4spd 4.33 I painted for a friend. http://rides.webshots.com/album/187328041oxAXRI |
master cyl
FOR MY TWO CENTS WORTH I BELIEVE THEY WERE BLACK PHOSPHATE PLATED PRIOR TO MACHINING. I HAVE TWO NOS MASTER CYLINDERS, ONE DATED 69 AND THE OTHER DATED 70. BOTH ARE BLACK PHOSHATE PLATED. MINE IS CURRENTLY AT STEVE D'S IN CA GETTING REPLATED. HE DOES EXCELLANT REPLATING AND IT IS NOT VERY EXPENSIVE.
63 Z-11 JACKSHAW CHEVROLET CAR 67 PLUM SAFARI WAGON 68 ROAD RUNNER HEMI 4- SPEED 69 RA V JUDGE 70 RA III 4- SPEED CONV. GTO 73 FIREBIRD 98 MUSTANG CONV 05 LEXUS SC430 CONV 08 LEXUS ES350 15 SILVERADO |
Many times there were differences in finishes for parts destined for the assembly line vs parts destined for Over The Counter Sales... An assembly line worker could care less about some surface rust PLUS the parts were used quicker so rust is less of an issue. Black Phosphate would have lasted on the 70 Judge Conv. as it still has all the rest of the original phosphating under the hood. (45k miles and garage stored it's whole life)
I'll go with the cheap black paint theory. I have found traces of black paint on most of the ones I've seen. I have an NOS 70 EB with the cheap black paint treatment.
master cylinder color
My 1972 455 ho gto sat in a basement from 1976 to 2006 and was driven in 4winters only. Ckeck the black treatment on the master and the GX sticker. GX for what? thanks from montreal.
bleeder screws
I'm not so sure about that. I've seen cars with or without them in books and elsewhere. More infos needed ? thanks
i think 69s were the only ones with bleeders..... all the ones ive seen have been rusty so im for cast iron.....
chucky how about a pic of your NOS masters?? have steved post Id love to see it. IS the EA stamped in the half moon from NOS or did that get stamped when installed???
http://gloryrestoparts.20megsfree.com/ 1970.5 Pontiac Tempest GT-37 400ci 4bbl 4sp 3.90:1 12.73 @ 112.42 2011 Pure Stock Drags 12.71 @ 110.58 2013 Martin FAST/FS race 12.70 @ 111.74 2014 Pure Stock Drags 12.60 @ 111.66 2015 Martin FAST/FS race 1968 Pontiac Firebird 400 TH400/3.08 open export car - factory heater delete 14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags 14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race |
Bleeder masters were on all cars up into the mid to late 70's. The 67-69 had the round master with the bleeders and the 70-77 had the square with the bleeders. From my experience all the disc brake masters had bleeders until around 76-77
Here you go Scott
Here are some pictures!
