4" or 6" Rim??
Happy Easter... I plan to run a 165/80/15 tire up front, which is recommending a 5" rim. However, the AR wheels I am going with are only available in 4" or 6" widths .
Since the tire size is right in the middle, I am sure either rim would work ok- but if I am going to go a little beyond the mfg recommendation, would it be better to go with the 4" rim or the 6" rim in this scenario?
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
That tire size is commonly used on older air-cooled VW bugs that came with 4” wide wheels from the factory.
Pretty small tire size for the front of a V8 American car, I ran that size on some 3-1/2” Centerline wheels on my GTO for a while. Not really ideal but if you’re going for a certain look you compromise. All that said the 4” wheel is a better looking choice but a 6” wheel will offer more stability, it all depends on what you’re trying to achieve.
Thank you for the comments. I am going for that fat & skinny look, similar to this pic... one thing about a 6" rim is I would have more flexibility to go to a larger tire like a 205/75 if I did not like the smaller tire. Decisions...
FWIW - the recommended rim width for a 165/80/15 is 4 - 5.5".
https://www.tirerack.com/tires/tires...omCompare1=yes Personally, I'd go with the 205/75/15 as the 165/80/15, besides being very skinny, is only 25.4" tall. The tread width on the bigger tire is very similar and the tire height is 27". Recommended rim width is 5 - 7". https://www.tirerack.com/tires/tires...omCompare1=yes |
Anything more than 26.1" diameter will rub on the rear side of the fender well on a firebird during turns, even with button head bolts. A 195/70 would be closer to stock diameter (25.7"), still be skinny, and the recommended rim is 5-6". And then with the 6" wide rim, in the future you could upsize to 205/65, 215/65, or even a 225/60 if you wanted. Lot more possibilities if you go with the 6".
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
"Anything more than 26.1" diameter will rub on the rear side of the fender well on a firebird"
Good to know. I currently have a set of MT front runners on the car in shop (4×28) , but springs are too stiff and car is at least 2" higher in front than what it should be. Since the MTs are fairly new, I am hoping they will work on the drag strip. With the skinny weld wheels, there appears to be clearance, but again the car is currently too high to effectively determine clearance. I noticed that most of the tires in a 195/70 are for trucks, but the 205/70 is pretty close and offer a good selection. Sent from my SM-G965U using Tapatalk
Another thing you might think about is braking, those skinny little tires will make your stopping distance a lot longer. Take my word for it I found out the hard way.
Hmmm.... I have been 126mph in one car and 137mph in another on "those skinny little tires" without stopping issues.
Not when a Cadillac pulls out front you a half a block away and your going faster then you should be.
...or that modern Hyundai with 4 wheel abs discs, decides to lock them up because a squirrel ran across their path. On a track in a straight line, with plenty of open shutdown area, sure easy-peasy. On the street that can be curved or straight, with other traffic, whole new ball game.
Quick update for anyone interested... after installing 200lb santuff drag springs and getting the stance correct... my 5" Weld Prostar wheels clear fine with a 4x28" runner.
I purchased the 6" AR Torque Thrust and installed 205/70/15 tires. Worked ok with just me in car, but with a passenger, outer front fenders would rub. I fooled around with spring spacers but then lost too much front end travel for my liking. I thought about selling the 6" rim and going 4", but the local tire shop was comfortable mounting a 165/80 on the 6" rim. So far so good, and I am happy with the look! Sent from my SM-G965U using Tapatalk
Thread Tools | |
Display Modes | |
