Old 05-06-2019, 02:21 PM
8LUG 8LUG is offline
Default 18 TOOTH SPEEDOMETER GEAR
1962 TO 1964 speedometer gear for super hydra matic/Jetaway wanted NOS yellow plastic 18 tooth gear
ID:	511699   Click image for larger version
Old 05-14-2019, 02:29 AM
6-pack 6-pack is offline
I have an 18 tooth speedo gear from my basket case jetaway, I don't know what its worth, but shoot me a figure and we can go from there. P/M me if you like.
6-pack
Old 05-17-2019, 07:16 PM
Default 18 TOOTH
[QUOTE=6-pack;6022941]I have an 18 tooth speedo gear from my basket case jetaway, I don't know what its worth, but shoot me a figure and we can go from there. P/M me if you like.
6-pack[/QUOTE Looking for a nos gear, the seal inside was shot and leaking transmission fluid inside the speedometer cable. they cant be taken apart and repaired. With a used one might be a leaker too.
Old 05-23-2019, 02:15 AM
Well 8LUG, all I can say is it has 40,000 miles on it and I can"t tell you it does not leak, your call.
6-pack
Old 05-30-2019, 08:10 PM
Hi 8LUG
Just curious, do you have any 8 lug rims for my 60 Bonnie? Need one for my spare tire.
6-pack
Old 05-30-2019, 09:18 PM
None for 60. Have 2 with 1964 date codes
Old 06-02-2019, 11:51 PM
Well, I don't know when they changed to 15" cause I have the 14' size. are yours 14"?
6-pack
Old 06-03-2019, 08:34 AM
Poncho60 Poncho60 is offline
All 8 lug rims are 14 inch OEM. Bigger sizes are aftermarket / custom.
Old 06-04-2019, 02:44 AM
Great, that answers my question. Now the big one, would you trade even the speedo gear for a good 8 lug rim? You ship your rim and I'll ship my gear. What do you think?
6-pack
Old 06-04-2019, 02:48 AM
That last message from me was for 8LUG, not Poncho60
Sorry, 6-pack
Old 06-04-2019, 05:42 PM
Default GEAR
6-pack
Speedometer gear would cost me about $100.00 /$60 for the rim and around $40 to ship. No thanks
Old 06-05-2019, 04:31 AM
No problem 8LUG. If you change your mind you know where I'm @. You might try Northwest Transmissions @ 937-442-2811, ask for Rich
Good luck
6-pack
Old 06-10-2019, 02:15 AM
8LUG, did you find your speedo gear at Northwest? Just curious and how much did they want for it?
6-pack
Old 06-11-2019, 06:59 PM
Default GEAR
First photo shows the gear that northwest has, Its all plastic. the guy said it pushes out of the case. Pushed mine out and the shaft is metal. Found a NOS gear this past week-end in Davisburg Mi. widetrackers swap meet $25.00. no more leaking. 2nd photo shows old unit and the box of the NOS unit. The replacement gear from Northwest was $40.00. I did well
ID:	513965   Click image for larger version
Name:	speedometer gear #1.jpg
Old 06-12-2019, 06:27 AM
stevep's Avatar
stevep stevep is offline
I use Northwest quite a bit but there are no deals there. John, the owner, is a transmission technical wizard and always helps me out.
Old 06-13-2019, 02:18 AM
Glad you found a replacement. the pics and info I'll save.
Later 6-pack
