Old 06-07-2019, 01:07 PM
92GTA's Avatar
92GTA 92GTA is offline
Default Upgrading from rear drums to discs - Wilwood front discs
My car has Wilwood front disc brakes, master cylinder, adjustable proportioning valve, and residual pressure valve. I have the factory drums brakes, hence the residual pressure valve.
I've bought a new rear end that is coming with disc brakes, so is all I need to do is just remove the residual pressure valve and re-adjust the proportioning valve?
Is it that easy? I just want to make sure.
Thanks!
1969 Pontiac Firebird
Old 06-08-2019, 11:26 PM
64speed's Avatar
64speed 64speed is offline
Yes just remove the valves
Old 06-09-2019, 06:24 PM
92GTA's Avatar
Thanks!
Old 06-09-2019, 08:09 PM
Are there not different MC's for drum/drum, disc/drum, and disc/disc?
Old 06-09-2019, 08:38 PM
92GTA's Avatar
Perhaps there is, but I have one that is agnostic:
https://www.wilwood.com/MasterCylind...temno=260-8555
Old 06-10-2019, 07:30 AM
punkin punkin is offline
I'm doing a 4 wheel conversion at this time. Wilwood sold me one of their master cylinders with the adjustable proportioning valve. They suggested the prop valve for additional bias adjustment (front/rear) but, their MC is for a disc/disc set up. I'm still not sure if the prop valve is really necessary.
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 06-10-2019, 10:45 AM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
When I put my Wilwoods on I used their adjustable proportioning valve and it was very much needed. My back brakes were locking up long before my fronts kicked in. A lot of hard braking test and adjustments later no matter how hard I hit the brakes now I stay perfectly straight. I'm not using wilwoods MC but I do have one made for four wheel disk.
67 Firebird Convertible
Old 06-15-2019, 11:01 PM
92GTA's Avatar
So this is the link to the part that I'm removing:
https://www.wilwood.com/MasterCylind...emno=260-13784
Searching eBay there are a lot of different brake line couplers for 3/16th hard lines. I don't know jack about flare types, can someone please help me out with exactly what type of coupler I need to replace that pressure valve?
Thanks!
Old 06-22-2019, 02:53 PM
92GTA's Avatar
I bought this one, hopefully this does the trick:
https://www.ebay.com/itm/3-8-24-Inve...53.m2749.l2649
