Old 06-18-2019, 09:45 AM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default tri-pwr carb stud
Could someone plz tell me where does the carb stud with the hole in it go?What does it connect to? Thank you
Tim
Old 06-18-2019, 10:18 AM
1969GiPper 1969GiPper is offline
Center carb, passenger side, rear. I believe usage depends on model and options.
Old 06-18-2019, 10:35 AM
wbnapier wbnapier is offline
That is correct.
It doesn't connect to anything.
I put a vacuum cap on mine and use it for tuning with a vacuum gauge. If you have vacuum advance you use the nipple at the back of the center carb. Maybe it was used for a dash vacuum gauge?
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 06-18-2019, 11:18 AM
Thank you guys,you're the best.How about fuel line sealing? Thanks again
Tim
Old 06-18-2019, 11:20 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default PHOTOS
I have seen this “Vacuum Stud” in two locations on a 66 Tri-Power.
1) First pic, RH side front of rear carb. Factory capped, if no Air Condition.
2) Second pic, same as above, but this 66 has a Vacuum hose attached to hollow stud for Air Condition.
3) Illustration showing the other location sometimes used on a 66.
Chris.
ID:	514393   Click image for larger version
ID:	514394   Click image for larger version
Old 06-18-2019, 11:28 AM
Thanks Chris,thats what I was looking for.I just moved and my books are still up north.
Tim
Thread Tools
Display Modes
