Auto tranny lines
Do the auto tranny lines run above the passenger frame? I see a bolt there I can only assume is also for the clamp to hold the lines down.
Yes they run over the frame.
There is bracket/separator bolted to the frame that holds the 2 lines together (and to the frame). And another clip that keeps them from rubbing against the frame. |
Thank you very much for the pics. It looks like I am missing the yellow plastic side frame clip.
My new lines from Inline Tube must be off a little. My clamp seems a bit wide for their bend design. The clamp flat is about 3/4" and the center to center of radius for lines is about 1 3/4", but the new lines are about 1 1/2". I can't fit the clamp between the lines. I may have to spread them. They're tight with the two band clamps they install to keep them together. I assume I have the correct clamp.
Thread Tools | |
Display Modes | |
