Old 07-17-2019, 03:19 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Difference between '67 Chevelle and GTO 4 piston discs?
Are there any differences between the Chevelles setup and the GTO setup? I picked up spindles brackets 2 piece rotors years.
Skip Fix
Old 07-17-2019, 04:53 PM
242177P's Avatar
242177P 242177P is offline
If they're original to the Chevelle, they're the same. Two things to watch for, 68s used different sized brake line fittings, and the F-body versions have smaller bores (GTO stuff is over 2")
Old 07-20-2019, 10:05 AM
Skip Fix's Avatar
Thanks. Calipers have the same casting number in my GTO book was not sure if the brackets were any different. I would not think they would be.
Skip Fix
