Old 10-04-2020, 10:37 PM
racerboy's Avatar
racerboy racerboy is offline
Default Space between dash and A-pillar
Not sure if I am describing this right, but there is a bit of a gap between the end of my dash and the A-pillar cover (I think that’s what it is called) on the driver side of dash. Is this normal?
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 10-04-2020, 11:24 PM
Aus78Formula Aus78Formula is offline
Normal, if ugly. There was originally a clear filler piece there, #20105596.
Old 10-05-2020, 01:21 PM
tdavidl's Avatar
tdavidl tdavidl is offline
hope you don't mind me jumping on this thread with a somewhat related question:
the 2 inch (or so) metal trim piece that runs the length of the roof from the A pillar to the rear has come loose on my 71 towards the middle & back & my 71 fisher body manual doesn't seem to show how they are attached....anyone know?
you'll see it here in post #8 on this thread...the seatbelt rides just above it..
http://forums.maxperformanceinc.com/...d.php?t=817679
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 10-06-2020, 07:43 PM
racerboy's Avatar
Thanks. Is this available in reproduction?
Old 10-06-2020, 07:51 PM
No, not even used. They crumbled to white powder on day 2. They are simply an insulator, that slides over the end, possibly to prevent noises when flexing. You could add rubber channel sleeve instead, not original but also hides what's inside that gap.
79 TA camel interior pillar insert by Aus78Formula, on Flickr
Possibly GrandAm Steve's pics:
Firebird dash pillar filler piece (3) by Aus78Formula, on Flickr
Firebird dash pillar filler piece (1) by Aus78Formula, on Flickr
Old 10-06-2020, 09:23 PM
racerboy's Avatar
That looks interesting. Where can that be purchased and could I paint it to match interior color?
Old 10-06-2020, 09:54 PM
None of the 70 models I've owned over the years had that part. Perhaps something that was used on cars built later in the 70s?
Old 10-06-2020, 10:20 PM
Formulabruce's Avatar
I believe it was installed on the a pillars as a sub assy just for shipping the parts or cars.
Old 10-07-2020, 08:29 AM
Norwood's Avatar
Norwood Norwood is offline
Never on a 70, others can speak beyond that
Old 10-07-2020, 09:37 AM
78w72 78w72 is offline
the headliner trim pieces attach with metal push pins, if they are still intact you can try gently pushing back in on that area. if it doesnt hold they may have broken off or lost their tension, remove it & investigate further.
