Old 10-14-2020, 05:30 PM
Dragncar Dragncar is offline
Originally Posted by 1969GPSJ View Post
I bought a Summit brand a couple of years ago. Car is still a project, and the starter is not mounted... I saw some mentions in the past that the unsupported nose of the mini-starter style is a problem Has anyone noticed that?
Do not quot me on this, but I believe the NA King runs a Summit starter( and a Melling oil pump)
I say, good enough for him, more than good enough for me. All these aftermarket starters are gear reduction and will turn the engine over slower than a stock starter. If you bend a non nose supported mini starter you have a big and very high CR engine. Or something else went wrong, too much advance ect. A lot of guys start cranking their engine, then light the ignition off after it is already spinning.
My cranking compression went down by a good 20lbs going from the long 455 factory starter vs the Summit.
Old 10-14-2020, 07:21 PM
GTOGEORGE's Avatar
IMI for me..........only the best for my Blown GTO!
GTO George
Old 10-16-2020, 04:45 PM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
I've ran the Powermaster for five seasons with zero issues. Four seasons on a 10:1 motor and this last season on a 13:1 motor.
Old 10-16-2020, 05:03 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
IMI on all my or son's tweaked engines/cars.........many Pontiacs (now only a 462 cid), AMC (413) and Oldsmobile (407).
Never any issues so far and great customer service. *They helped "custom" make a version for a 'newer' Jeep / AMC V8 / Torque Command engine / trans swap.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 10-16-2020, 05:30 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Tildon on my 78 since late 80s. Repaced a solenoid over the years. I did have to drill and tap to reclock it to clear the headers better.
Tried a Summit on the 81. had to clock it upside down to clear the RA exhaust manifold and it was toast after about 6 months.
The 500IA has a RobbMc on it.
Skip Fix
Old 10-16-2020, 11:14 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
RobbMc with pinion support. 535 with 16 to 1 at 16 volts with a locked distribution and start retard (all considerations) spins quick and free even when hot.
Used an IMI for years on 474 at 11 to 1 and 462 at 12.5 to 1 successfully. For current combo switched to the RobbMc because it was clockable ( need that feature in my application) and pinion support for bigger cubes and compression.
Old 10-17-2020, 11:26 AM
ta man ta man is offline
Robb MC here as well..I like the clockable feature. I clock the solenoid at the bottom. I added the pinion support a few years ago when I raised my compression. I've also increased my initial timing over the years and the starter still spins over great.
Old 10-17-2020, 12:55 PM
1969GPSJ's Avatar
1969GPSJ 1969GPSJ is offline
So, I guess what I am asking is that for a mild compression ratio (eventually aluminum head, 10.5:1 cr), Pro Flo4 fuel injected, non-race car, long branch HO manifold equipped street beast, less than 500 cubic inches, does anyone think that the unsupported nose of a Summit starter (or similar types) will be a problem in a manual transmission '69 GP? In addition, I will definitely have a jumper wire on the solenoid and use an external solenoid to supply power to the starter.
Old 10-17-2020, 01:41 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Should work fine. I had one that worked on a mid 10-1 455 that lasted along time. It struggled with the 10.8-1 517 on hot starts so I bought a new one and it did the same thing.
Went to a Powermaster Ultra-Torque 9410 and it’s worked good for 3 years now. It’s a permanent magnet type and has more balls than the PM XS series or the Summit but does cost a bit more
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 10-17-2020, 04:47 PM
1969GPSJ's Avatar
I think it would appear that this Summit starter should be fine for my application, and when it eventually goes, I will probably replace it with a starter from: https://www.robbmcperformance.com/index.html Thanks for the replys!
Old 10-17-2020, 07:13 PM
Jim Scites's Avatar
Jim Scites Jim Scites is offline
IMI Just 10:1 compression. When I was changing engines I misplaced the starter bolts, I couldn't find them anywhere and I couldn't find replacements either. I called IMI and in a few days a new set of bolts came free of charge. I will never use another starter as long as IMI is in business.
Go Fast... Return... Go Fast Again... Who cares about left turns???
