Old 02-15-2009, 10:53 PM
lemans411's Avatar
lemans411 lemans411 is offline
Default pics of my turbo 535 build
this is my turbo 535 . got my hotside done this weekend heres some pics
ID:	158141   Click image for larger version
ID:	158142   Click image for larger version
ID:	158143   Click image for larger version
ID:	158144   Click image for larger version
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
Old 02-15-2009, 10:59 PM
lemans411's Avatar
some more pics
ID:	158146   Click image for larger version
ID:	158147   Click image for larger version
ID:	158148   Click image for larger version
ID:	158149   Click image for larger version
-Rob
68 gto
Old 02-15-2009, 11:03 PM
David Holmberg's Avatar
Very nice!!!!!
Old 02-16-2009, 01:01 AM
70 bird's Avatar
70 bird 70 bird is offline
Thumbs up
I like it! What size turbo?
Old 02-16-2009, 01:16 AM
lemans411's Avatar
its an 83 mm garrett 1.32 a/r turbine.
-Rob
68 gto
Old 02-16-2009, 01:25 AM
70 bird's Avatar
That should support some serious power. How much are you shooting for?
Old 02-16-2009, 06:28 AM
krisr's Avatar
krisr krisr is offline
f&*k me!
Old 02-16-2009, 07:09 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Dammmmmmmmmmmmmmmnnnnnnnnnnnnnnnnnn!!!
Old 02-16-2009, 10:04 AM
lemans411's Avatar
Talking
hoping for high 900's to 1000
-Rob
68 gto
Old 02-16-2009, 12:03 PM
se428bandit's Avatar
se428bandit se428bandit is offline
Wow,very nice.What car are you going to use this moror in.
Old 02-16-2009, 12:39 PM
lemans411's Avatar
the 67 lemans in avatar also did a mini tub and coil overs in the rear. gained 3.5 inches of wheel well space
-Rob
68 gto
Old 02-16-2009, 06:36 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Oh Oh, looks like my Turbo Poncho is going to have some competition?
Looking GREAT Rob, might be time for a couple of diapers one for the car and one for you when you sh*t yourself!!!!
Can't wait to see it out.
Old 02-16-2009, 06:52 PM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
Default ?
What did you use for piping for your manifolds?
Did you mig or tig them?
What wastegate are you using?
I am getting ready to start cutting/welding mine.
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
Old 02-16-2009, 07:04 PM
taff2's Avatar
taff2 taff2 is offline
Lemans, I think you're gonna need that extra 3.5" of tyre ! What vehicle did that 88mm Garret come on originally?
Old 02-17-2009, 12:30 AM
lemans411's Avatar
they are schedule 10 stainless straight pipe and weld els
the manifolds were mig welded due to lack of tig experience but all the piping to the turbo and wastegate were tig welded after we got some practice with the tig
the wastegate is a tial 60mm
-Rob
68 gto
Old 02-17-2009, 12:39 AM
lemans411's Avatar
thanks ed. yup you better look out lol. as soon as i shave a 1000 pounds off my car i'll be able to keep up with you.
thanks for the help with the manifold design too
i will be putting some plastic down the first time i take her out
-Rob
68 gto
Old 02-17-2009, 12:40 AM
lemans411's Avatar
not quite sure what it came off of . a big dump truck probably lol. its a t18a40 83mm
-Rob
68 gto
Old 02-17-2009, 01:28 AM
Steve Barcak's Avatar
Looks pretty wild! Keep us updated. Good luck with it.
Steve
Hosting 11th annual Pontiac Heaven, show, swap, drags, party and all around good time. Saturday April 4, 2009 at Speedworld near Phoenix, Az
more info- www.pontiacheaven.org
Also hosting- 7th annual Nostalgic Show and Go! and swap. Drags, cool car show, parade, special exhibitions, gassers, rails, stockers, customs and much more. coming Sunday April 5, 2009 to Speedworld. Phoenix, Az -This is Arizonas longest continuest running nostalgic event, our 7th year! www.nostalgicshowandgo.org
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 02-17-2009, 01:31 AM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
id hit that.
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 03-15-2009, 11:54 AM
lemans411's Avatar
finally got all my intercooler piping done . gettin ready for the dyno on the 25 th
got the body off too gotta send the frame out to get blasted and lots of welding and grinding left in the wheel wells from the mini tub
ID:	161876   Click image for larger version
ID:	161877   Click image for larger version
ID:	161878   Click image for larger version
ID:	161879   Click image for larger version
-Rob
68 gto
