Old 07-26-2020, 04:26 PM
Scott Stoneburg's Avatar
Default Crank Trigger Question
Ok, I'm new to installing a crank trigger. I set the balancer at 30* timing which is where i plan on starting qith the tune up. Then adjusted the magnetic pick up to line up with one if the magnets on the balancer. Is that how its done? Seems right but just wanted to make sure I didnt miss something.
ID:	545860   Click image for larger version
Old 07-26-2020, 05:23 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
That’s how I did mine. I also phased the rotor. Then verified timing with a light.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 07-26-2020, 06:24 PM
Cool. I will make sure to phase rotor when i get to the distributor. Thanks
