Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
#41
I plan to keep the 555 with twin 475's to a max of 15 psi. I cant even imagine 35 psi.
#42
lol That would be insane! I bet at 10 pounds you would make more then me.. lol
My Half AN Injun..... |
#43
probably. But the heads flow over 400 cfm at .700, so 10 psi is really moving some air.
#44
yeah but you will be a lot more efficient and your air temps will be cooler ...
#45
If you keep it down on boost I think you will be fine...555 ci??? man that thing is going to be hauling a$$
#46
or did the metal crush under the T washers and still hold the stud. |
#47
But I looked up a similar 540 ci BBC with the same S475's and 1.32 A/R's.....dyno results were 1800 ft/bs at 4800 rpm and 1800 hp at 5900 rpm.....27 psi. That pull started around 3300 rpm and torque was already over 900 at that point and increasing fast. |
#49
TimeWarp FYI the cv1's have some considerations for higher heat and better cooling built in. Internal water passages and what appear to me to be "cooling veins"' in the bolt boss areas. The other bonus is the aluminum they are cast from(355) and hardness its treated to, has better properties in higher heat applications. AFR uses same alloy(slightly different heat treat), possibly a few others, but most other head manufacturers use 356 alloy which costs less. The convertible exhaust directs a lot of exhaust heat above the center bolt easing heat-load problems there.
Jim Sammons can give you more detailed information as could Bill Anderson. |
#50
DCI RA5 heads problem solved!
GTO George |
#51
We are talking budget, not a re mortgage!!
#52
So you want to go fast ......you just don't want to spend any money, gotcha! What about safety is that a budget too?
GTO George |
#53
GTo George, I think those would be a bit over kill for a low boost 800 hp engine.
Basically should i put the money into my e heads or get a set of cast heads and have them done? If the stud pulling through can be easily solved for a low boost application i would just rather use the heads I have as they already have nice parts on them. |
#55
You can use your heads. Have the chambers opened and "softened" some and if need be dish your pistons to get your compression down.
#56
Not everyone has a track car. My car has seat belts (modern) front and rear, cup holders, 2 phone charging ports, cd and mp3 player..... and a turbo to run down the modern muscle cars. Of course the old Pontiac is better looking than the new muscle cars!
#57
That's exactly what it does , just bulges out under the T-washer and wedges the stud...
#58
#59
GTO George |
