Old 01-23-2023, 09:50 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Default Cast iron head porter suggestions please.
I see that SD Performance no longer ports cast iron heads per their website.
So.. who would you all recommend??
I've got a set of 12s and a set of 62s that I'd like done.
Rob
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 01-24-2023, 09:31 AM
chrisp chrisp is offline
Spott's Performance
The Following 2 Users Say Thank You to chrisp For This Useful Post:
Old 01-24-2023, 10:48 AM
Paul C at Carter Racing may be one place to check. He may or may not be porting iron heads.
Another one that was part of an engine build I got involved in is Dan Barton. He ported a set of 72 455HO heads that I had Paul C rebuild and flow test. The port work on those were excellent. Don't know if Dan is still porting iron heads these days or not.
Iron has seemed to fall out of favor with most head porters when you have a market flooded with aluminum offerings these days.
https://youtu.be/XqEydRRRwqE
Old 01-24-2023, 12:15 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
this place says they do. no personal experience as of yet.
http://www.nitemareperformance.com/
bill has in the past (has a nice cnc macine), don't know if he still does.
http://carlquistengines.com/
“We don’t build a ‘luxury’ car. We build a performance car then we make it luxurious.”
The Following User Says Thank You to Matt Meaney For This Useful Post:
Old 01-24-2023, 01:02 PM
chiphead's Avatar
chiphead chiphead is offline
Marty Warden in Charlotte NC area did a set of 670s for me
The Following User Says Thank You to chiphead For This Useful Post:
Old 01-24-2023, 01:48 PM
grivera's Avatar
grivera grivera is offline
JBP ports iron heads but it looks like you buy directly with option to send in cores. Would be worth asking if they'll just perform the work on yours: https://butlerperformance.com/i-2445...tegory:1234782
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 01-25-2023, 11:57 AM
Stan Weiss's Avatar
Jim Robertson He posts on this forum.
Stan
Pontiac Pump Gas List
Old 01-25-2023, 01:00 PM
Steve C. Steve C. is offline
Also consider Paul Knippen who posts here. He is very adept at porting cylinder heads and has a flow bench. His cell is 630-400-4441
Old information here:
The Following 2 Users Say Thank You to Steve C. For This Useful Post:
Old 01-25-2023, 03:47 PM
Dragncar Dragncar is offline
Stan
He has the highest flowing set of Pontiac iron heads on earth. So yeah, Jim.
How many other guys run a 8 second NA Pontiac with D ports ?
Old 01-26-2023, 02:26 PM
slowbird's Avatar
slowbird slowbird is offline
Jim is a bad dude, but I don't believe he's been 8s or even knocking on the door of 8s
Paul Knippen knows how to make power
The Following User Says Thank You to slowbird For This Useful Post:
Old 01-26-2023, 02:28 PM
Bill Eveland's Avatar
Did you try Automotive machine in Pekin? Alan left whats left of Mullvains or weddle and works over there now I believe. Id never stop foot in that shop again. they tried screwing me over and everyone else apparently
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 01-26-2023, 02:49 PM
Stan Weiss's Avatar
What I have on this list is 9.48 @ 142.87 @ #3385
If anyone has any faster runs for Jim please forward me that information.
Stan
Old 01-26-2023, 04:37 PM
I am thinking about a thread or post from not too long ago. Had a sheet metal intake, think car was blue and his son and new bride was in the pic.
He did do the 320cfm pair of 48s that made 871 HP. Not sure if it had any power adder but you would think it could have.
Old 01-26-2023, 05:51 PM
slowbird's Avatar
Why can't you just say sorry i was wrong??
https://forums.maxperformanceinc.com...d.php?t=860361
Not close to 8s. Jim is great, no need to embellish what he's done.
Old 01-26-2023, 11:16 PM
He did do this. 871 HP out of a stock block is pretty good.
https://forums.maxperformanceinc.com...ght=320cfm+48s
Name:	Screenshot 2023-01-26 at 19-14-19 Best head porter on the planet today - Page 4 - PY Online Foru.jpg
ID:	606102   Click image for larger version
Name:	Screenshot 2023-01-26 at 19-14-52 Best head porter on the planet today - Page 4 - PY Online Foru.jpg
Old 01-26-2023, 11:18 PM
slowbird's Avatar
Like I said he's a bad dude but I'm not seeing 8s anywhere like you said.
Old 01-27-2023, 03:09 AM
slowbird, I am simply thinking out loud , trying to figure who has done it. It has been done, iron heads in the 8s.
Might have taken a light car, so what. The Butlers had some guy do it years ago with D ports;
Dan had a guy who could run 8.90s with his RAIVs a long time ago too.
But for some reason you want me to admit I am wrong.
Jim has been 9.39 with 96s. That a pump gas head.
8s are possible with smaller chamber, more CR and lighten the car up. Or real close to it.
Old 01-27-2023, 08:01 AM
slowbird's Avatar
You are wrong, you said Jim has ran 8s, he hasn't. I agree iron heads can go 8s, heck Marty ran 7s and so has Jim Y but that's not what you said.
Jim's 9.39 was not on pump gas and was not low compression. You need to check your "facts" better.
Old 01-27-2023, 08:03 AM
joes455 joes455 is offline
Jim is from pics on his site does great work
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 01-27-2023, 08:16 AM
I also wanted to add getting good low lift flow #s 265 @500 is fairly easy with little work on the short turn.After 500 or right when ,and it will #s will fall off by 20-30.The talent of porting the d port is getting that 265 back and biting at the str to extend that to 300 or 325.I wonder if he is using or any other porter of these heads a 2.19 valve?Cast heads are tough, messy,hazardous to the lungs,kills burrs,takes time and porters don't get paid enough
