1969 T/A Stripe stencils or layout?
I need to lay out the Trans Am stripes on my 1969 and the Kit that I ordered from Ames a month a go is still on back order. Does someone have the dimensions or a template available to lay out the tape for the tyrol blue stripes? Thx.
1970 T/A |
This is from Assembly Manual, not sure how good it will look or if it will work for you.
email me for the full size pic johnta1@wallaceracing.com
Thx
Will send an email. Dave
1970 T/A |
I had the 69 TA stripe stencil kit from Phoenix Graphics. The shop layed it all out but seemed the paint leached under the stencils. (may have had heat or dried out prior to me receiving it) but ended up costing me extra 2,500 to strip repaint white and then they hand laid out the stripes using tape.! Came out dead on !!
The assembly manual view tells you all the dimensions to lay it out yourself. I use blue 3M Fine Line Tape for all my stripe jobs. Absolutely no paint bleed if surface is prepped good. Keep the tape clean, straight and in the wrapper.
FYI- The assembly manual dimensions might be incorrect.
The manual calls for 1/4" thick edge stripes with a 1/8" space between the center strip and edge. I believe the edge stripes should be 1/8" thick with a 1/4 space between the center strip and edge.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
The Following User Says Thank You to RAJ7395 For This Useful Post: | ||
Raj is correct, in that it is striping width is reversed in the assy manual.
The Following User Says Thank You to johnta1 For This Useful Post: | ||
Thanks John!
Those dimensions are exactly what I needed. Thx for your help on this. Dave
1970 T/A |
