Heater control light
So what do you do if the prong thing that hold the black socket in the control housing is missing?
Anyone make it or something else to get socket to stay. I think it’s used in two locations on a 69…?
Send it! It’s going home on a trailer. |
If they're like mine, you may find it inside the controller.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
exactly, same problem (and same piece) with clocks and dash tach.
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
And the rear arrowhead lights for 68.
69 Tempest / LeMans too? The metal ring has tiny barbs that supposedly lock into the plastic socket. When replacing a bulb they sometimes pull out of the plastic creating a larger hole for the barb to lock Into. I've thought whether filling the small holes with epoxy and then pressing the ring into the epoxy would help keep the metal ring in place. I haven't seen the metal rings reproduced. I have seen same design NOS sockets on ebay for Olds and Buick from time to time. Don't know if they're the same size.
x3
i have a couple spares if needed |
My MO when running into this is to fish the missing thingie out of the clock or heater control etc. Ever so slightly bend the hooks so they bite better, inject a drop of crazy glue into each hole in the rubber, install a new bulb and reinstall it and never touch it again. We will hopefully die of old age before it needs replacing!
The Following User Says Thank You to north For This Useful Post: | ||
Just like North posted, I do the same. Bend the barbs out a little and toss a dab of some adhesive in there before pushing the barbs back in. I used PC-7 epoxy last time.
Doorman Help! #85805 worked perfect in my quarter panel side marker lights. |
The Following User Says Thank You to Entropy11 For This Useful Post: | ||
I don’t even have the prong thing
So you've confirmed that it's not in the unit?
In that case Entropy's post looks like a good bet.
Greg Reid Palmetto, Georgia |
I believe that inline also sells a clock harness that includes two sockets including the metal prongs.
Heater control night time lamp
Hi, is this the part your talking about?
Peter Serio Owner, Precision Pontiac |
No, but that will work. The inline item I was referring to is a kit that has two of those fittings and the “Y” wire that connects the clock housing to the grey rheostat wire of the dash harness.
Peter, those are close to it.
The in line parts probably work too. Probably need to cut and re do wire connection.
