Old 12-29-2023, 09:33 PM
Default 71 455 ho engine PQ trans rear and more.
I'm listing these parts for sale for a private owner. Taken off of a restored 71 trans am original 455 ho car. Unfortunately the owner went pro touring with LS power and custom chassis. I have the engine complete minus air cleaner with trans still in the subframe with everything on it. Driveshaft gauges steering column radiator and shroud. Wiring harnesses gas tank and fuel lines. Heater and AC boxes. This was a running restored documented car. Everything is in very good to excellent condition. Will have pics and numbers this weekend.
15000 for everything. Also have the rear with sway bar. 23181 area code. Pm if you’re a serious buyer.
Old 12-30-2023, 10:29 PM
Some pics
ID:	625744   Click image for larger version
ID:	625745   Click image for larger version
ID:	625746   Click image for larger version
Old 12-30-2023, 10:34 PM
Few more
ID:	625748   Click image for larger version
ID:	625749   Click image for larger version
ID:	625750   Click image for larger version
ID:	625751   Click image for larger version
Old 12-31-2023, 12:44 AM
Very nice looking package. The TA must be same
Old 12-31-2023, 01:38 AM
65madgoat's Avatar
Just curious. I see a lot of 455 HO intakes NOT painted engine color. Is there a reason why? I think it has been noted that all came from the factory painted - yet so many are NOT painted like this one?
Comments?
Sweet deal. Too bad guy went LS though.
Old 12-31-2023, 08:05 AM
johnta1 johnta1 is online now
I always thought they looked better unpainted.
chiefbigb, what is the block casting code, 485428? or 483677?
Old 12-31-2023, 02:53 PM
Some more
ID:	625772   Click image for larger version
ID:	625773   Click image for larger version
ID:	625774   Click image for larger version
Old 12-31-2023, 02:57 PM
485428 block casting..
ID:	625776   Click image for larger version
ID:	625777   Click image for larger version
ID:	625778   Click image for larger version
ID:	625779   Click image for larger version
Old 01-08-2024, 11:28 PM
I think the 455 HO intakes were bare in 1971, painted in 1972.
Old 01-08-2024, 11:59 PM
JSuchma JSuchma is offline
I have an original untouched 71 455 H.O. intake that still has the factory-applied paint on it. FWIW
Old 01-09-2024, 12:33 AM
Back in the early 90s I purchased a ‘71 HO intake from a parts dealer Terry Rosebush that I found in Hemmings Motor News, it still had the remnants of the original paint on it.
Old 01-09-2024, 07:00 PM
Definitely painted in 71
Old 01-09-2024, 08:00 PM
I owned two 71 455HO cars. One was a Trans Am and one was a Formula. Both were built the second week of February 1971 in the Norwood plant. Both intakes were bare (unpainted). When I had the TA engine apart I wasn't sure if the intake should have been painted, so I called the original owner and he confirmed that the intake was bare when he bought the car.
The Following User Says Thank You to eaglesan13 For This Useful Post:
Old 01-09-2024, 08:40 PM
Since it appears there is a discrepancy, it may come down to the plant and shift as the determining factor.
Old 01-10-2024, 02:21 PM
I'm willing to paint the intake if that seals the deal lol
The Following 4 Users Say Thank You to chiefbigb For This Useful Post:
Old 01-31-2024, 03:52 PM
I was asked about a price on the complete engine and transmission. 11k would get them. Would break up the rest from there.
Old 02-04-2024, 09:03 PM
Believe that to be correct part number distributor
Old 02-04-2024, 09:15 PM
4dblnkldude's Avatar
I am interested in the dizzy, how much?
Old 02-04-2024, 09:27 PM
Are you selling Parts separately?
Old 02-05-2024, 08:06 AM
I'm not parting everything out at this time. Would sell the engine and trans together. Then part the rest out. The package is a good deal by today's standards. I did not list the part number of the distributor
