Old 02-24-2023, 08:51 AM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default 1969 T/A Stripe stencils or layout?
I need to lay out the Trans Am stripes on my 1969 and the Kit that I ordered from Ames a month a go is still on back order. Does someone have the dimensions or a template available to lay out the tape for the tyrol blue stripes? Thx.
1970 T/A
Old 02-24-2023, 12:18 PM
johnta1 johnta1 is online now
This is from Assembly Manual, not sure how good it will look or if it will work for you.
email me for the full size pic
johnta1@wallaceracing.com
Old 02-24-2023, 12:41 PM
dpoltzer's Avatar
Default Thx
Will send an email. Dave
1970 T/A
Old 02-24-2023, 03:37 PM
StevenK StevenK is offline
I had the 69 TA stripe stencil kit from Phoenix Graphics. The shop layed it all out but seemed the paint leached under the stencils. (may have had heat or dried out prior to me receiving it) but ended up costing me extra 2,500 to strip repaint white and then they hand laid out the stripes using tape.! Came out dead on !!
Old 02-24-2023, 04:10 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
The assembly manual view tells you all the dimensions to lay it out yourself. I use blue 3M Fine Line Tape for all my stripe jobs. Absolutely no paint bleed if surface is prepped good. Keep the tape clean, straight and in the wrapper.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
Old 02-24-2023, 07:47 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
FYI- The assembly manual dimensions might be incorrect.
The manual calls for 1/4" thick edge stripes with a 1/8" space between the center strip and edge.
I believe the edge stripes should be 1/8" thick with a 1/4 space between the center strip and edge.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
The Following User Says Thank You to RAJ7395 For This Useful Post:
Old 02-24-2023, 08:19 PM
Raj is correct, in that it is striping width is reversed in the assy manual.
Old 02-24-2023, 09:40 PM
Did a search and found this thread:
69 TA Stripes
Old 02-28-2023, 12:29 PM
dpoltzer's Avatar
Default Thanks John!
Those dimensions are exactly what I needed. Thx for your help on this. Dave
1970 T/A
