Sandalwood question
For those with sandalwood interiors, when in original CLEAN condition, does it have a "mottled" look to the vinyl/soft surfaces?
I'm working on a 70 with sandalwood that hasn't been cleaned in 30+ years. I have one of the panels exceptionally clean, yet it appears to have slightly darker spots throughout the surface that I call "mottled". It could be deeply embedded dirt, but I can't quite tell.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
Yes originally will have slightly darker, spots in vinyl. Very subtle. Whatever you do, don’t paint dash, steering column and kick panels the lighter color as door panels. These should be a little darker color
Sandalwood interior colors
I'm assuming GM installed a darker color dashboard to make is less "glaring" in the sunlight while driving - I've seen Parchment interiors on other GTOs with a Black dashboard, probably for that same reason. Any insight as to what my dashboard color is will be appreciated. Note: ignore the A-pillar color in one of the photos. I painted it Sandalwood, thinking it was incorrect and, depending on what the dash color is, I will return it to the proper color. I've also included a close up of the original seat color, where you can see that mottling that one of you asked about.
Thanks, Bob M. 1970 GTO Convertible Originally: Sierra Yellow/Sandalwood Int/ Sandalwood Top w/ 400 4BBL Auto Trans Currently: Red/Sandalwood Int/White Top w/ 400 4BBL Manual Trans Built in Baltimore Plant - 1st week of Nov. 1969 |
Ok, that's what I was hoping to hear. I didn't think I could get it any cleaner
Yes its evident the other parts (column, dash, etc) are darker. The dash has one crack in it, so far leaving it. Thought of trying the dash cover, but I think a company is out there that will recover the original dash. Do you happen yo know if the darker parts are saddle?
I believe theres actually a dark sandalwood which probably would go with the original sandalwood. My 70 gto is saddle with different interior parts and carpet dark saddle. And my door panels are also the mottled look.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Thank you that's helpful too.
I've been trying to search the correct color for the package tray. I don't know if it's sandalwood or the darker shade.
My gto has dark saddle carpet,dash vinyl,kick panels and rear package tray,,everything else is saddle. The door panels are saddle but the carpet on the bottom of the door panel is dark saddle.
1970 Parts Book paint codes for Sandalwood:
interior semi gloss Medium Sandalwood Du Pont 9716-L Ditzler 23323 Dark Sandalwood Du Pont 9727-L Ditzler 23324 interior 0% gloss Dark Sandalwood Du pont 9704-L Ditzler 23311 no medium Sandalwood listed |
Would this imply that the package tray was originally a shade darker? I can't find any info anywhere and I ordered samples from Ames.
The original one was removed and replaced with tan audio carpet.
My 70 is code 255 saddle but the original package tray was dark saddle. I had legendary make me a new one the same color.. Im assuming your rear tray would be dark sandalwood.
Thread Tools | |
Display Modes | |
