Old 08-11-2024, 09:47 AM
Jimbobeast Jimbobeast is offline
Default brake cylinder tilt?
Why is the master cylinder on a 1970 GTO tilted and not flat? Is there some engineering advantage?
Old 08-11-2024, 11:17 AM
242177P's Avatar
242177P 242177P is offline
Power brakes used the lower hole on the pedal's arm.
Versus the manual ones using the upper hole. Because
leverage. And now the pushrod is angled. If you wanted
a flat master that'd mean lowering the booster, and you
can see how that wouldn't work. HTH
The Following User Says Thank You to 242177P For This Useful Post:
Old 08-12-2024, 08:54 PM
Kinda makes sense, in a mass-production assembly line kinda way. Thanks.
The Following User Says Thank You to Jimbobeast For This Useful Post:
Thread Tools
Display Modes
