battery ground, where? 1966 Bonnie
Finally putting the engine back in the car.
Where does the battery neg. cable attach on a 1966 Bonneville? TIA, Ed S |
It attaches to a studded head bolt, pretty sure it’s the second one from the front of the head.
Also, to make sure you have a good ground. Make sure there is a good cable from the engine to the frame & engine to body. So many times I have been chasing electrical gremlins on vehicles. I first use a set of jumper cables to tie everything together, engine, chassis & body, gremlins go away! Need good grounds!
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
So lets assume that the stock ground stud is long gone to ARP type fasteners. What would be a good plan B?
Ed S |
If you have an unused 3/8-16 threaded hole on the front of the head that would be a great place to attach the ground cable. Be sure to scrape or sand off any paint at the grounding point.
Thread Tools | |
Display Modes | |
