Old 02-22-2020, 06:02 PM
76TA462 76TA462 is offline
Default 455 Mains
On an OEM two-bolt main, 1976 455, is there enough material, size, width or whatever to drill them and tap the block to make them four-bolt mains, or are the mains totally different between the two. Thanks.
Old 02-22-2020, 06:22 PM
PAUL K's Avatar
PAUL K PAUL K is offline
All the 455 blocks are good. Plenty of room.
Go fast, see Elvis!
Old 02-23-2020, 10:34 AM
78w72 78w72 is offline
how much power do you plan to make? street or race? i was told by many reputable pontiac engine builders & others that these 2bolt 400 & 455's can support 600hp with studded 2 bolt mains. i stuck with studded 2 bolt mains on a stroked 400 with 500+ hp.
Old 02-23-2020, 02:57 PM
It was a thought that dogged me for years as the engine was gradually built up. With my engine now being re-assembled it popped up again. I checked and you are correct. The builder advised that the 2-both main is plenty strong for my build (just shy of 575 hp and tq at the crank)., and especially for the rpms it will see.
Old 02-24-2020, 07:21 AM
steve25 steve25 is offline
I have run the 2 bolt mains with studs at the 650 hp level for well over 20 years and never had a issue!
I did fully prep the main caps though, spending some 12 minutes on each cap polishing and rolling over all the sharp edges but for the Bearing parting line.
weather your concerned about main cap related failure or not then you should find a balance shop that can balance to less then 3 inch ounces which makes for a huge improvement in loads and strain!
Note the black Crank scraper that's worth 12 free HP.
Old 02-24-2020, 08:16 PM
Will Will is offline
I've been told the same thing by reputable builders so have always just studded the 2-bolt mains. I'm never going to build an engine over 600 HP, so good enough for me.
