Old 02-24-2020, 05:13 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Stock rods? Rod side clearance? Piston pins. Press fit or float?
  #42
Old 02-24-2020, 05:42 PM
mgarblik mgarblik is offline
I agree with several posts here that suggest getting your engine builder in the loop right away. Since he is local, that is a huge plus compared to removal and shipping out of town. I am sorry to say this, but it probably isn't going to fix itself. So be prepared to remove the engine again and it will need to be opened up. The way the engine was set-up isn't a recipe for a nice quiet street engine IMO. Bearing clearance is loose, about where I would set-up a mild race engine. The piston to wall clearance is almost double what the manufacturer recommends. Not sure why it was put together that way.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
  #43
Old 02-24-2020, 06:08 PM
abefromen's Avatar
abefromen abefromen is offline
Bushed Eagle H-beams
.0015 side clearance
Floating pins
  #44
Old 02-24-2020, 06:17 PM
abefromen's Avatar
I have absolutely no clue either. Apparently some feel they know better than what the manufacturer says it should be.
  #45
Old 02-24-2020, 06:44 PM
PunchT37's Avatar
I don`t think the bearings are shot because of the good oil pressure. I don`t like the .005 piston clearance. But, my 5.3L LS motor has a piston slap when cold. You can hear it up top till it runs for a while. Yours sounds fine up top. 8 pistons slapping would be loud but, should quiet down once warmed up. What I don`t know is the piston pin clearance in the rods. If the exhaust ain`t leaking, it might be time to get that builder to fix that thing.
  #46
Old 02-24-2020, 07:48 PM
abefromen's Avatar
This engine is opposite, relatively quiet at cold start up then the racket really starts to get loud as it warms up.
My daily *****box Chevy Lumina with the 3.1 raps LOUD at cold start but when fully warm it's quiet.
  #47
Old 02-24-2020, 08:04 PM
PunchT37's Avatar
Are those stock rocker studs and stock length pushrods? And, has the heads or the block been milled?
  #48
Old 02-24-2020, 08:05 PM
Will Will is offline
Please explane fully what you mean by dirt & grit?
In my time I have seen motors rebuilt in which the shop that did the cleaning and machining work left glass bead in the block & oil passages .
Many times the glass bead was stuck to sludge in the oil galleries that did not get hot tanked out with the result that the glass bead came loose once oil was pumped over them and within 10 minutes of the new motor running took out the Bearings , chewed up the Pistons skirts and wipped out the rings!
This.
"Dirt and grit" in an oil filter from a freshly rebuilt engine spells trouble. It's not unusual to see a little silver glitter from rings & such wearing in but "dirt and grit" is completely unacceptable.
I can't understand how people can stay in business building engines when they are as sloppy and dumb as this "engine builder" seems to have been.
Really sorry to read this. IME, there are not that many "engine builders" who actually do good work and I'm super picky about who I trust to do it.
  #49
Old 02-24-2020, 08:25 PM
tom s tom s is offline
IMO oil pressure is not the end all.Oil flow is more important at low RPMs like 2000 when breaking in a FTC.Really heavy oil can show high oil pressure but might be hurting the film cooling and lubricating bearings.I have never been a big fan of heavy oil.FWIW,Tom
  #50
Old 02-24-2020, 08:32 PM
abefromen's Avatar
yes, yes and no.
  #51
Old 02-24-2020, 11:01 PM
NeighborsComplaint's Avatar
Originally Posted by abefromen View Post
I agree with that all except I would find it hard to believe there was a cam issue not saying it isn't possible of course.
Initial oil change flushed most of the contaminants out. If gritty deposits could have been wear-in cast-off embedded in break-in lube,
Subsequent oil changes will tell the whole story. Check the oil and filter until satisfied you are seeing clean oil.
I set my crankshaft clearances to the high side of stock tolerances and piston clearance (SpeedPro forged) to dead center of Mfr clearances and the motor is free of mechanical noises. The prior build was loose as a goose and the pistons (reused Venolia pistons from the prior owner's build w light honing) slapped and sounded like a diesel when cold.
Triple Black 1971 GTO
  #52
Old 02-25-2020, 08:51 AM
steve25 steve25 is offline
Just because the heads and or block have not been milled does not mean the base circle of the Cam your running is the same as a stocker!
Any change will make a need for different lenght push Rods depending on how you set the lifter preload.
Since it seems your running stock rocker studs you then have no way to make the needed adjustment which could be done atleast a little bit if you had adjustable set up of straight rocker studs and poly locks.
Valvetrain issue come in two forms it seems, noisy when cold, or noisy when hot unless something is way far out of wack, and then it's noisy all the time!
  #53
Old 02-25-2020, 03:11 PM
geeteeohguy's Avatar
My opinion, FWIW, is that there is no issue with the valvetrain of this engine. The issue is that it was assembled with clearances that were too large and is loose enough to be noisy. May run forever like that.....may not. I like to build mine on the low side of the spec, not at or past the top side. Why rebuild an engine to worn-out specs?
Jeff
  #54
Old 02-25-2020, 03:45 PM
abefromen's Avatar
You're opinion is most likely 100% correct.
  #55
Old 02-25-2020, 04:17 PM
Dragncar Dragncar is offline
The .005 piston to wall is very strange to me. I was somewhat concerned about my 461 build at .006 and called Butler to run past what I did since I bought my pistons from them. Talked to David Butler and he told me they run .005 on street strip engines will filled blocks. Your engine is defiantly not one of these. In my case .006 is right where I want to be in a 700HP build with 11-1 and open headers with filled block.
One poster had the idea of getting some Race Tec pistons with a custom dia so you can get the clearance you want without re boring the block. Expensive and a pain to do it all over. But it would tighten things up for sure. You could run some coated bearings and that would get you .0005 tighter on the bearing clearance.
Your machinist has some explaining to do.
Thing is, this engine is a textbook case of rebuilt cast rods and good ol cast Silvolite pistons at .0015 and run it. Completely stock engine with stock cam. Full floating forged pistons with matching H beam rods are overkill. Even H beams with pressed pins and TRWs @ .0035 would be better.
Sometimes overthinking things works against you. More of a chance for miscommunication.
I hope it all works out for you. Might be best off to just run it, you have good pistons and rods. It should quit down when fully warmed up.
  #56
Old 02-25-2020, 04:43 PM
abefromen's Avatar
It should quiet down when fully warmed up.
Odd thing is, the opposite is true.........
When cold it's a bit noisy but not bad, as it starts to warm it slowly gets progressively louder to what you hear in the vid. Thats at full operating temp which is 195.
  #57
Old 02-25-2020, 04:55 PM
dataway's Avatar
dataway dataway is offline
If that is really true then it wouldn't seem to me to be a piston clearance issue. Aluminum expands considerably more than cast iron. Excessive piston clearance almost always quiets down after an engine comes up to temp.
Granted the "hole" will also expand as temps rise in the block, but the aluminum piston will expand more.
  #58
Old 02-25-2020, 05:33 PM
abefromen's Avatar
I agree.
Or maybe the clearance is beyond the .005 who knows, but it's obvious something isn't right. If not the pistons then another issue.
Eventually it will be disassembled and inspected to find out what is wrong.
  #59
Old 02-25-2020, 05:40 PM
Joe's Garage Joe's Garage is offline
Default Warm engine noises, in our experience, are usually bearing-related or lifter-related.
As previously stated, really thick oil will give you an indication of where to look.
Lifters that get loud when heated up will usually be noticeably quieter. Bearing noise sometimes goes completely away with thick oil.
And, also stated previously, bearing problems can sometimes be identified by holding your hand against the oil pan with the engine running.
If that engine were mine, the 'engine builder' would be helping me take it out and take it apart, right there in my garage, so we could document with photos EXACTLY what is found. I wouldn't run it any more than necessary.
Tell him to bring his good micrometers and his reading glasses.
Good luck!
  #60
Old 02-25-2020, 05:58 PM
abefromen's Avatar
Good luck!
He's aware of the issue and hasn't offered to do anything, other than insist the pistons are not the problem.
