Old 02-28-2020, 05:08 PM
Pontiac Performance Author
Tom s yes both. What show is mark coming out to see ?
  #102
Old 02-28-2020, 06:20 PM
tom s tom s is online now
He is coming out for the Seal Beach car show.Tom
  #103
Old 02-28-2020, 08:01 PM
78w72 78w72 is offline
what & when is the seal beach car show?
  #104
Old 02-28-2020, 08:04 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
https://sealbeachchamber.org/seal-be...-show-gallery/
Karl
The Following User Says Thank You to 72LuxuryLeMansLa. For This Useful Post:
  #105
Old 02-28-2020, 08:26 PM
will start another thread.Tom
The Following User Says Thank You to tom s For This Useful Post:
  #106
Old 02-28-2020, 09:14 PM
mgarblik mgarblik is online now
A quick way to see if the noise is related more towards a rotational issue or recipercating issue is to warm the motor up so its noisy, then shut her down and either pull off all of the odd number or even number plug wires, then jack up the idle speed a good amount and restart the motor and see if the noise heard has changed.
If the motor had roational noise issues then the motor will sound the same when running as before the plugs where pulled.
That is an interesting technique I have never heard of or tried. Pretty hard to keep a V-8 running on 4-cylinders I would think. Going to have to try that sometime. Cool idea.
  #107
Old 02-28-2020, 09:39 PM
I'm thinking it's wrist pin clearance + piston clearance. Piston clearance is partially SRP's fault. They give a range of clearances rather than a specific clearance as illustrated by Mick's Ross piston card.
A word about piston Alloys: 2618 does expand more than 4032 , but not much more. It's only 5-10%. The cold clearance vs running clearance has more to do with the contour (aka cam) of the piston than the alloy.
I was surprised that my recent set of 2618s required only .005" vs .008"-.010" for 2618s 30-40 years ago. Apparently a lot of research has been going on regarding piston "cam".
  #108
Old 02-28-2020, 09:47 PM
There is an old time "save" for the pistons. It's called "Knurling". Check out an old timers engine shop to see if has the tool. Last build I saved with the knurler was the SD Iron Duke I built For PMD and Car Craft in '84.
  #109
Old 02-28-2020, 09:54 PM
Ken,
Recognizing your experience and expertise, (I have neither) . If the problem was excessive clearance piston to wall, would there be tell tale signs on the piston/cylinder wall? If the excessive clearance is between the piston and wrist pin wouldn't there also be tell tale signs?
Mainly I'm asking if there is any way to tell where this noise is coming from without an autopsy and will the above mentioned senarios tell the tale?
Karl
  #110
Old 02-29-2020, 04:00 AM
John Milner's Avatar
John Milner John Milner is offline
Sure sounds like there is an exhaust leak that might at least be responsible for some of the noise. Hopefully the noise nothing major. I have certainly ran forged TRW’s with .005 clearance that were quiet. Can’t comment on other brands though. Good luck.
  #111
Old 02-29-2020, 07:27 AM
steve25 steve25 is online now
If it's a Exh leak at the head to Exh Manifold flange then pulling off one plug wire at a time will greatly change the noise level being made and even make a slight difference in the noise level heard if it's due to a leak at the Heat riser shaft, or at the head pipe to Manifold coupling.
  #112
Old 02-29-2020, 08:30 AM
TheGrudge TheGrudge is offline
Abe Fromen - sorry; I’ve been tempted to ask you for some time...
Are you the Abe Fromen, sausage king of Chicago?
  #113
Old 02-29-2020, 12:56 PM
Ken,pistons dont get more noisy when warm they get quiet!He said it is quiet cold and get noisy hot!Tom
  #114
Old 02-29-2020, 02:21 PM
abefromen's Avatar
abefromen abefromen is offline
Quiet-er but not completely quiet.
  #115
Old 03-01-2020, 05:38 AM
dataway's Avatar
dataway dataway is offline
Let me diverge for a moment from the specific topic. I have a 2011 GMC truck, with the 5.3, aluminum heads, 80K miles, using 10-30w synthetic it's whole life. On a cold winter day, say 5-10 F, I get filter bypass squeal for about 2 seconds, and piston slap for about 5-10 seconds, and ... what actually sounds like a rod knock for about 1 second on a dead cold startup ... normal? Otherwise the engine runs like a top, purrs like a kitten at a saucer of milk.
  #116
Old 03-01-2020, 12:44 PM
I would say normal, but that engine should use 5W30
Bill Nye.
  #117
Old 03-01-2020, 01:23 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Yeah. Drop it down to 5w30 in winter. Mine has had what sounds like a rod knock when cold since around 17,000 miles. Has 160,000 on it now. Runs fine. Does not burn a drop of oil. I have run top end cleaner in it a couple of times. The knock goes away for approx 5000 miles or so and slowly returns. It really doesn`t knock at all on startup in the summer. Engine has to be cold. I don`t worry about it now.
  #118
Old 03-01-2020, 06:11 PM
dataway's Avatar
Next change I'll go to 5w30. Thanks guys.
  #119
Old 03-01-2020, 09:39 PM
footjoy's Avatar
footjoy footjoy is offline
if I missed some thing let me know.
you have choices
1. Get the builder over to listen and look at it.
2. Get another professional to come over and listen to it to diagnose it.
3. Keep reading this thread and miss the whole summer.
There is a lot of good information in this thread but you will have to take action.
I have an engine with 2000 miles on it back at the machine shop. but mine was self inflicted.
Good Luck
Greg
