Rear carrier ID
got this carrier in a box of parts, I think its a BOP 8.2, 3.55... Cant really find any casting numbers, can anyone tell me what year, or if its a safe track, or open?
another pic
I'm thinking a 66 safe track? it has 4 pinion gears... and a 3.56 gear set...
What part number & dates are inscribed on the outside edge of the ring gear & the face of the pinion head?
Ring gear bolts are not '64-69 Pontiac 8.2. Have a good feeling it's later, then there would only be two possibilities...
Look for the date code on the ring gear.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Ring gear 39-11 GM 6690
Pinion says 39-11 GM 69 E A Looks like a new set of gears, no wear anywhere... And I'm pretty sure its a BOP 8.2, has a 2" tall deck? GM 8.2" 2.73:1 and down, 2-series, 1.615" deck height 3.08:1 and up, 3-series, 2.000" deck height Last edited by wooftfd; 10-30-2021 at 01:01 PM. Reason: error |
It's a 1969 4 pinion 8.2" with 7/16" bolts.
so... This will fit in a 1964 rear end, and will take my stock axles?
Sorry if its a dumb question! Maybe a little more info... 64 421, compression at 9.5, ram manifolds, tripower, mild head work on 716 heads, 3.35 rear ratio, stock 4 speed, stock sized tires, no track time, but will jump on it from time to time... 64 housing and axels ok to use? Last edited by wooftfd; 10-30-2021 at 03:59 PM. |
It will fit any 64-72 8.2" Pontiac rear. You should check the condition of the posi before you install.
Would recommend JD Race, he just did mine 330-990-8155
