Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 09-21-2006, 10:18 PM
Brett_ty's Avatar
Brett_ty Brett_ty is offline
Default "entropytec" ebay radiator specialist
Anybody ever dealt with this guy before? what do you think?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
You are bidding a new Entropy radiator for a '64 - '67 GTO (with or without A/C) with dual Spal fans, custom aluminum shroud, TIG welded custom overflow canister and braided overflow line. If you need unadulterated cooling for your Pontiac that will keep your engine cool in the summer heat, with even with the A/C blasting, this is for you. Fits in the stock mounts and utilizes the factory upper hold down clamp for a drop-in installation. Also includes dual Spal HP fans (not the cheap Spal fans that don't move enough air to cool even a weed wacker). Please specify if you have an A/C or non A/C car and a manual or automatic transmission. The automatic transmission version includes a trans cooler at no additional cost. This unit features all aluminum construction, a nocklok forced nitrogen brazed core, two rows of 1.00" cooling tubes, precision TIG welded construction through out, strong 6061 hose connections, TIG welded aluminum overflow, brass drain cock and braided overflow connections. This unit does not have an integrated transmission cooler and will require an external transmission cooler with an automatic transmission. Buyer pays actual shipping costs and insurance. Visa/MC, Cashiers check or money orders accepted.
Smilies are Off
