Old 01-22-2023, 09:59 PM
8453johng 8453johng is offline
Default 1980 turbo pace car rear end paint
question was the rear end painted semi gloss black on the 19802 pace car trans am
I thought the pictures i have seen is the rear left the factory natural
As always thanks again
Old 01-23-2023, 12:27 AM
Natural cast steel center, natural steel tubes. On the 3.08 posi coded rears, believe there was a large orange inspection mark on the bottom of cast center housing. Will ck a few original '80 housings to confirm.
Old 01-23-2023, 12:29 AM
Default Thanks
thanks as always
mine doesn't look pretty but I don't to paint where there was none
Always looking to make better but original
Old 01-23-2023, 06:33 AM
alex s's Avatar
alex s alex s is online now
Here are some pictures of a 1980 F Body (Z28)
with under 200 miles
ID:	605794   Click image for larger version
ID:	605795   Click image for larger version
Old 01-23-2023, 11:17 AM
78w72 78w72 is offline
Originally Posted by 8453johng View Post
thanks as always
you can always use paint colors to match the natural finishes and prevent ugly rust.
Old 01-25-2023, 10:48 PM
Here are two from a 1981 Turbo TA. Found them after sand blasting
Name:	trans Am rear end marking.jpg
ID:	606041   Click image for larger version
Name:	trans Am Rear marking 2.jpg
