Old 12-29-2023, 01:30 AM
8453johng 8453johng is offline
Default 70 GTO 455 Ram Air Question
There is a 70 GTO 455 on E Bay now that is in Rapid city South Dakota
Originally Gold per the PHS
My question is this the PHS shows 455 Automatic
At the end it says 1970 engine ID page: 7040268 with ram air but below it has a carb listed as 70405781
I believe one carb is automatic and the other stick
When you bought a 455 was Ram Air standard or an option the engine ID page is confusing
I went to Eric Whites book 1970; optional 455 L75 still not clear
I can say this I have looked on E Bay for over 2 decade every week for 1970 GTO's. Really a passion.
455 PHS documented GTO's don't come up often.
As always Thanks Again for any help
Old 12-29-2023, 08:48 AM
Held for Ransom's Avatar
Per the car on eBay, it would have had a 7040268 as it was not RA. A RA auto carb would be 7040270. Ram air was an option and would show up on PHS, code 601.
So long, farewell.
Old 12-29-2023, 09:20 AM
241 units = 455HO with RamAir Automatic
302 units = 455HO with RamAir Manual
Option 601 = HD Air Inlet = RA Induction/Fresh Air , RA carburetor 270 or 273
455HO with RamAir was also a no-cost alternate to the RamAir3 400 on a 1970 Judge
Only 14 units produced - all were Automatic
11 Hardtops - 3 Convertibles
Old 12-29-2023, 09:32 AM
Kenth's Avatar
Kenth Kenth is offline
The planned 1970 455 Ram Air A/T carbs 7040278 / 7040578 and M/T 7040279 / 7040579 never happened.
These engines finally recieved the 400 Ram Air 3-4 carbs A/T 7040270 / 7040570 and M/T 7040273 / 7040573.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 12-29-2023, 03:05 PM
I wonder if this was the same car, although text indicates 400 car...
https://forums.maxperformanceinc.com...8&postcount=45
So long, farewell.
Old 12-29-2023, 04:20 PM
Kenth's Avatar
This? No T42 Hood Air Inlet though.
https://www.ebay.com/itm/37514652743...Bk9SR9qf1_OWYw
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 12-29-2023, 05:19 PM
One thing note worthy about it -
Its the first Automatic 455HO I have seen with Special Order Axle (from 3.07 to 3.31)
Although whoever red highlighted the breakdown sheet didn't pick up on the ratio upgrade.
Have seen a couple or few Manual 455HO with the option (from 3.31 to 3.55)
The seller got a little overly ambitious in his description text calling it 455HO Ram Air
Old 01-03-2024, 07:20 AM
RAIV70TA's Avatar
RAIV70TA RAIV70TA is offline
Wonder how many of the Canadian 455's were RA?
Old 01-03-2024, 10:52 AM
JSuchma JSuchma is offline
Did the 70 A-BODY 455 H.O. cars come with RA exhaust manifolds ? I have always wondered about this, but have never seen a positive answer.
Old 01-03-2024, 11:41 AM
No, not from the assembly plant.
Standard log manifolds & matching head pipes were how they were built.
Old 01-03-2024, 03:11 PM
Positive they did not.
Mine is a matching number unrestored project.
Still has the bent over tabs on the exhaust manifold bolt washers ,,, of the log manifolds.
You just got the RA carb and RA induction.
Even if it was an alternate engine option in a 70 Judge.
According to Gary Caves all original survivor Jvert.
Old 01-03-2024, 06:26 PM
Is that price in line with the value? I think it has good bones and might be worthwhile if you had a suitable drive train looking for a.home. It was actually on my watch list. Not as a player just as an interesting car.
