GREAT find! Couple of things...It looks like Blue Charcoal, which is a non-pinstripe color, although I've seen BC cars with a stripe like yours. White stripe or red stripe. Also, it looks to have a '64 shifter in it, which goes with the early build date. It has the same custom wheel covers and whitewalls mine came with, but mine are long gone. Very happy that you are merely preserving it and not restoring it. What a piece of history,a nd thanks so much for sharing it with us.
Jeff |
it is Blue charcoal.
It always had the white pinstripe. the shifter is a 1964 style with no hurst logo on it. it also has the early dash with no redline on the tach. the wheel covers are the original ones. the car came with red line tires and the original owner had them removed prior to delivery as he told them he wanted white wall tires not the red lines. |
It appears you have rally guages and then I read you have a clock. You can't have both. By adding a clock to the rally guage cluster would devalue that option in my opinion. By adding a tach to a non rally guage car would add some value. Not sure what is up with both of those options.
Better Pic
This angle shows the complete rally gauge cluster including tach. There is no clock in this dash.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
A VERY nice find. Congratulations! It looks like it has been living a very pampered life. Time to change all the fluids, belts ,hoses and take a long cruise. Oh, how old are those tires?
That is a great looking 65, Now go have some fun in it.
Cuz68 |
Great Find! I have a Blue Charcoal 65 GTO, 36,000 miles it has a white pinstripe on it too. Leave the car the way it is!
What a great find.
And a very cool GTO. Is that you in the 3rd pic with the sh!t eating grin? Definitely need some pics of the paperwork, maybe the cowl tag?
I will have to go thru the paperwork to see when the original owner installed the tires. They are ..GoodYear Custom Power Cushion Polyglas F78-14 Last edited by RAII 4-speed; 06-14-2013 at 08:45 AM. Reason: added quote |
The younger guy in the pics is my Son, The older guy is the original owner of the car.
After that, he most likely would have put on radials. They need to be replaced with new tires regardless - if you plan to drive the car. |
I think I know who thinks they are going to drive this mostly.
In August 64 , the 65's would have been open for ordering and the 64's already closed down . All supporting criteria "should" have been in dealers hands no later than September 64. Maybe his dealer was perhaps behind the status quo - but if it was ordered in October/November 64 - they should have had everything in hand by then. Who is to say for sure now tho about that particular dealer. Myself , probably wouldn't sling that detail of story around unless i had a 64 order form that Orig Owner filled out . Even then , things like Tach&Gauge cluster and the exterior color would have had to have had supporting 65 ordering literature criteria . Neither of those would have been 64 offerings . iirc that color was not used in 64 - T&G definitely was not . Every original date coded part on the car should have 1964 dates. But with post-65 model year break on the month coding . With exception of some limited carry-over late 64 model year parts. Anything dated later than late July 64 , is a 65 model year part. Hope that all helps some. Very rare to find any 65 with Orig Owner and that well preserved. TriPower 4spd Vert ..... .... .... small needle in a big big cornfield . |
The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
I just found this paperwork in the file. Here are some old notes the original owner wrote .This may help Last edited by RAII 4-speed; 06-14-2013 at 05:01 PM. Reason: added paperwork |
I appreciate the owner's notes, particularly the item about the GM 45 day strike. That's good data and probably helps to explain at least part of the delay. My car was ordered in late summer of 1964; built in Pontiac and delivered on September 18th, 1964. It was expedited to us so that it would be off GM property before the strike hit. Make sure and look for build sheets in the car while you are cleaning and detailing; if you can find a build date that might help determine if the car was built early in the year and stuck on property (or in process) due to the strike; or if it was built closer to the December timeframe and shipped right away after completion. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 06-14-2013 at 09:26 PM. |
The Following User Says Thank You to Keith Seymore For This Useful Post: | ||
Congratulations on your purchase of a very special car in stunning condition.
1961 Corvette 4spd. 1969 Chevy K5 Blazer - currently restoring |
#38
Thank you.
#39
The Following User Says Thank You to RAII 4-speed For This Useful Post: | ||
#40
very very nice, enjoy it
1967 RAM AIR GTO 1 OF 156 AUTOMATICS |
